I need a larger trans cooler for my late '99 F350.
I really would like to get a 6.0 cooler and install it but finding one at a reasonable price is difficult.
What other coolers do any of you run in addition to the small stock cooler-something of good quality? where did you mount it? got any pictures? Thanks!
Here is a link to a good choice. Mounting is right in front, directly behind the grill. You might try searching around a little bit because I believe I saw some vendors sell them with bracket kits for our trucks. (can't remember where I saw it though....)
I found my 6.0 tranny cooler at the local salvage yard for $50 bucks. A few bent fins was the only damage. Radiator shop cleaned and tested for $40 bucks. Its ready to go in the truck as soon as I get the 6.0 IC back from the rad. shop after cleaning and testing.Got that one from the same yard for $100 bucks. Will be installing both at the same time.
Look around you will find a good deal. I'm sure I can get more as they arrive. I think the other salvage yard here has the 6.0 IC for arround 2 bills If onyone is interested.
I also installed the Hayden 1404 04 1405 something like that (the Largest one) tranny cooler. Mounted right in front of the air conditioner condensor with the supplied hardware. I purchased mine from my local RV shop for $45. Only had mine for a couple of weeks, hope it helps with my hot tranny temps. while pulling my 12k# 5er. up still inclines with low speeds.
