Sponsored by: Real Truck
trans temp
Old Jun 28, 2008 | 12:44 AM
northey87's Avatar
northey87
trans temp
I am asking this for my grandfather he has a 2000 f-250 with the 5.3L diesel and I am not sure what trans gets paired up with it, but he is wanting to know what the trans temp should be running normally. Thanks for the help.
Old Jun 28, 2008 | 12:49 AM
monsterbaby's Avatar
monsterbaby
not towing mine runs about 60-70deg above ambient, towing 80-90
Old Jun 28, 2008 | 04:06 AM
Monsta's Avatar
Monsta
Sit. Stay.
WOW! A 5.3L diesel! How can I get one?
Old Jun 29, 2008 | 03:59 PM
northey87's Avatar
northey87
What is "ambient"? out side air temp? engine temp?
Old Jun 29, 2008 | 04:39 PM
tex25025's Avatar
tex25025
Ambient is outside temperature.
Old Jun 30, 2008 | 08:19 AM
northey87's Avatar
northey87
okay, but what would be considered too hot? if he is towing, in the middle of July, in Palm Springs and its 120 outside, that would mean his trans would be running about 200-210.
Old Jun 30, 2008 | 08:24 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, that's right, and there's nothing wrong with that.
The maximum short term (less than 1/2 hour) temp is 250F. The maximum sustained temp is 220F.
If the trans goes over 220F for more than 1/2 hour, or ever hits 250F, find a safe place to stop and idle the truck in park or neutral. NEVER shut the engine off when the trans is really hot.
Old Jun 30, 2008 | 11:52 AM
kenneBF250V10's Avatar
kenneBF250V10
Sorry to hijack this thread but I have a couple of questions for Mark.
Does the same hold true for the 4R100 and other trannies as well? I've been told in the past that once you start hitting the 190-195 degrees, that's the danger zone.
Also, what is your opinion about bypassing the in-radiator tranny cooler? Could I get my tranny to run cooler if I bypass it and just run my auxillary cooler (pictured below)? It just seems like that if my coolant is running at between 180-190 degrees and the trans fluid is being routed through the radiator, then my trans fluid is being heated to whatever the coolant temp is.
One last thing. Is one gallon of trans fluid flow per minute normal for a 4R100?
The reason I ask these questions are because my tranny temp has been getting up to 190-200 degrees on a hot day just with normal highway and a little stop-and-go (traffic) driving. That doesn't seem right to me.
Thanks,
Will
Old Jun 30, 2008 | 12:38 PM
monsterbaby
Will I can answer a couple of your questions, first this thread is about a 4R100 (thats what trans would be in a 2000 F250 PSD)
Next the 190-195 is often used as the safe limit but it's an old school number based on the old type F fluids, the newer fluids are a lot less prone to damage by the extra 20 degrees. IF you can keep the trans temp below 190 you are better off of coarse (ideally 170-180 is actually about perfect trans temp, but ideal and reality are different issues many times)
As to the aux cooler question, yes you can bypass the radiator adn in hotter climates I recommend it but I would suggest a bigger aux cooler then the one you have if it's your only trans cooler and your in a hot area.
Old Jun 30, 2008 | 12:49 PM
Mark Kovalsky
Yes, the numbers I stated hold for the 4R100. The "always keep it under 200F" crowd is wrong, in my opinion, backed with engineering tests and materials knowledge.
That's only a good idea if you want your trans to run hotter. It's a cooler, not a heater. It NEVER warms the trans fluid.
Your coolant runs about 190F, then is cooled in the radiator, then passes over the trans cooler. The coolant is anywhere from 15-100F cooler after the radiator than 190F. That's why there is a radiator, to remove heat from the coolant. The in tank cooler is a VERY effective way to ALWAYS cool the ATF. I've tested this from -40F to +120F and the ATF is ALWAYS cooler coming out of the radiator than it was going in. Even with a warmed up engine at -40F, the radiator is sucking heat out of the ATF.
Yes, that's the nominal flow rate at engine idle speed.
With some stop and go driving that seems right to me, depending on what ambient you're in. Anywhere from 60-100F above ambient is normal.
Old Jun 30, 2008 | 04:42 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Mark, not to question anything you say, but ...
My '01's tranny runs at 150 degrees, even when it's over 90 degrees outside, regardless of whether I am doing stop-and-go or pulling any load or on the highway. Which is right at that 60 degree difference.
If it's going up to 190-200 without a load and just cruising around normally, that is usually the sign that the 4R100 is going to lose it soon. So many people have had that happen, I can't even begin to count the number after all the years of being on this site.
Again, not to question anything you say, but so many people have reported that they lost their 4R100 after running around for years at 150 degrees, and then suddenly going up into the 190-200 range.
kenneBF250V10, didn't you just change the fluid? Does your tranny have one of those funky cooler-bypass valves in the lines?
Old Jul 1, 2008 | 07:20 AM
kenneBF250V10
Yes I did just have it flushed last weekend using the BG system and MERCON V.
If you are talking about the bypass line that is physically mounted to the passenger side of the tranny, then yes I still have it on there.
Speaking of the tranny flush. In the week since I've had it done I have noticed a difference in shifting firmness. The Monster Box that I have is designed to have firm shifts and shift firmly it does. I've always ran MERCON but since I've had it flushed and filled with MERCON V, the shifting seems to be less firm, especially under full throttle. Does anyone know if this is normal?
Old Jul 1, 2008 | 08:40 AM
krewat's Avatar
krewat
Without really knowing, I'd say it's somewhat normal - why? Because Mercon V when I first switched one of my MN12's (t-bird/cougar 96/97) over, I smelled it, and it smelled of limited-slip friction-modifier.
The intention was to reduce the torque converter lockup shudder, and it certainly cured that in both the t-bird and the cougar.
So yeah, I'd expect it to let the clutches slip a little more, and not "chatter" or bang into gear as much.
Maybe the bypass line is stuck slightly open? But how to tell? Point-and-shoot thermometer?
