Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
check engine light
Old Jun 27, 2008 | 03:46 PM
itswrongway's Avatar
itswrongway
check engine light
I could use some suggestions on code problem. My 2001 ford escape 3.0 v6 spit out a p0351 code which is a coil problem on num.1 cylinder. so I changed the coil and plugs since it was all apart (114500 miles on factor plugs wow) I cleared the codes and the engine runs fine. thru. the light came on with the same code p0351 what am I missing ?
Old Jun 29, 2008 | 01:41 AM
JJ98's Avatar
JJ98
check the wires to the coil and make sure its good there easy to brake and its bolted down good could just be a short
