Missing when engine reaches operating temp
Old Jun 26, 2008 | 08:28 PM
qleon's Avatar
qleon
I have a 94 f150 with the 300 six. It runs fine when it first starts up but when it reaches operating temp it starts missing so bad it can't be driven. Could this be the coil?
Old Jun 27, 2008 | 12:01 PM
Lazy K's Avatar
Lazy K
How long since it had a tune-up? Plugs, wires, fuel filter? Have you checked for any error codes? You can find out how to do that at fordfuelinjection.com
Old Jun 27, 2008 | 01:27 PM
straightsixer's Avatar
straightsixer
Don't think it would be the coil. If you had a multimeter you could ohm the coil cold first then ohm again when its running crappy.
Old Jun 27, 2008 | 09:05 PM
qleon's Avatar
qleon
truck has new plugs, wires, distributor car, coil, and fuel filter. still does the same.
Old Jun 28, 2008 | 08:47 AM
Lazy K's Avatar
Lazy K
Pull some plugs and see what color they are. Should be a tan color. It might tell if it is a fuel problem.
Old Jun 28, 2008 | 09:54 AM
quicklook2's Avatar
quicklook2
what kind of plugs and other parts?
