Trans Temp gauge ?
Old Jun 26, 2008 | 04:37 PM
Welk49's Avatar
Welk49
Trans Temp gauge ?
When installing the trans temp sender in drivers side of trans do you just screw the sender into the trans or is there and adapter you need? The autometer gauge I have came with adapters but they seem to big for what I would need. Any help would be greatly appreciated.
Old Jun 27, 2008 | 06:51 AM
Neal 97 250's Avatar
Neal 97 250
You should be able to use the 1/8"npt fitting it came with. If the hole is larger use an adapter. Put some thread sealer on there.
Old Jun 27, 2008 | 04:41 PM
Welk49's Avatar
Welk49
thanks got it installed and I have a problem temp is running at 225. Have an aftermartket cooler on there, and just changed the fluid and filter a week ago.
Old Jun 27, 2008 | 04:50 PM
Welk49's Avatar
Welk49
anyone have any ideas on what I should look for? Should I have kept the stock tranny cooler in and added the second one to the system.
kabcpapc
1997 - 2003 F150
Sep 6, 2014 03:53 PM
snowdog79
Jan 23, 2014 10:28 PM
gmm
Apr 8, 2009 07:11 PM
carrfamilynj
Jun 23, 2007 07:16 AM
jnye6625
Mar 22, 2007 11:25 AM
