Sponsored by: Innova
Mucho Bad Vibes.
Old Mar 4, 2001 | 10:33 PM
daywalker's Avatar
daywalker
Mucho Bad Vibes.
Well I just swapped out the front speakers and re-did the rear setup. Sounds really really nice. Except for at certain frequencies in a song (generally lower) parts of my roof will start vibrating (the door does also but that stops when you hit it) does anybody else have this problem or know how too deal with it. It sure can mess up a good Led Zepplin song.
Daywalker
92' F-250 351 4x4 xlt 4.10 5spd supercab longbed
Sound System: Stock Stereo, RockfordFosgate 800 watt amp, Vega 18" sub (400 watt rms), one Cerwin-Vega LS-12 3 way floor speaker with the Vega sub removed (because I blew it) and a RockfordFosgate 12" sub (500 watt rms) in its place. And one Boise floor speaker with a 75 watt power capacity (you know it ain’t gonna last). A pair of Pioneer 6-3/4 speakers up front with 180 watt max (50watt recommended)
Performance Mods: K&N Air Filter.
Cosmetic Mods: Black Grill Guard, 5% window tint, bug guard, bed liner.
http://albums.photopoint.com/j/View?u=1426655&a=10683799&p=36629681&Sequence=0&re s=high
Old Mar 4, 2001 | 10:54 PM
tonka's Avatar
tonka
Mucho Bad Vibes.
Hi
Sounds like you could use some sound deadening material. It almost looks like heavy tar paper that sticks to the inside of your vehicles body panels , It can also be applied under the carpet to help kill road noise among other things . There are several different ones on the market but it can be very expensive .You are best to check your local stereo shop for price.
tonka
Old Mar 5, 2001 | 09:24 AM
odinmurphy's Avatar
odinmurphy
Mucho Bad Vibes.
I would agree that you need some sound-deadening in your truck. You can get either the actual Mat form, or you can buy it in a canister and spray it on your panels. If you are going to pull out headliner, I would use the mats, on the doors use the canisters.
Good Luck
Murph
Old Mar 5, 2001 | 08:00 PM
dust3's Avatar
dust3
Mucho Bad Vibes.
I found a real cheap source for sound deadening material.
http://www.sounddeadeningmaterial.com
"Someone put this together so I must be able to take it apart!"
Dustin
Old Mar 6, 2001 | 08:42 AM
daywalker's Avatar
daywalker
Mucho Bad Vibes.
Have you bought and used this stuff? If so what are your opinions.
Daywalker
Old Mar 6, 2001 | 12:09 PM
odinmurphy's Avatar
odinmurphy
Mucho Bad Vibes.
I bought some of this stuff from MCM Electronics, not sure if it is exactly the same, I used on the floor of my Bronco. It is a little hard to apply. Have some extra adhesive on hand, the backing adhesive sucks. Also Have a good heat gun on hand. I makes the material much more pliable.
Good Luck
Murph
Old Mar 6, 2001 | 06:57 PM
daywalker's Avatar
daywalker
Mucho Bad Vibes.
hey thanks, i'll let you all know what happens.
Daywalker
Old Mar 6, 2001 | 07:14 PM
dust3's Avatar
dust3
Mucho Bad Vibes.
Yeah I've used the stuff I posted the link to, it worked very well with no adhesion problems. I'll see if I can find a picture of it.
"Somebody put this together, I must be able to take it apart! "
Dustin
Old Mar 6, 2001 | 09:35 PM
dust3's Avatar
dust3
Mucho Bad Vibes.
[font size="1" color="#FF0000"]LAST EDITED ON 06-Mar-01 AT 10:43 PM (EST)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 06-Mar-01 AT 10:42 PM (EST)[/font]
Here's a pic. https://www.ford-trucks.com/dcforum/User_files/3aa5bbce169086b5.jpg
Dustin
Old Mar 10, 2001 | 12:40 AM
tonka's Avatar
tonka
Mucho Bad Vibes.
Hi
I've never used the spray ,does it work as well as the mat?
Nice job dustin.
tonka
Old Mar 12, 2001 | 03:05 PM
odinmurphy's Avatar
odinmurphy
Mucho Bad Vibes.
If You need to do an entire floor, or some big area, use the mats. The spray works good where there are too many things in the way to place a mat down, like inside doors, and on the firewall behind the dash.
Good Luck
Murph
Old Mar 13, 2001 | 09:15 PM
killer4x4's Avatar
killer4x4
Mucho Bad Vibes.
btownsoccerstud
Apr 20, 2005 02:46 AM
Fordbyford
Apr 11, 2005 03:52 AM
daywalker
Jul 22, 2001 12:24 AM
daywalker
Feb 21, 2001 09:44 AM
daywalker
16
Feb 19, 2001 02:08 AM
