frame repair
Old Jun 26, 2008 | 07:46 AM
dotcentral's Avatar
dotcentral
frame repair
I have a rusted out section where the radiator support mounts to the frame. What gauge metal is the frame of a F100? It is a 66, not sure if it varied from the earlier trucks.
Old Jun 26, 2008 | 01:57 PM
cobraguy's Avatar
cobraguy
A piece of 1/4"-3/8" X 2" flat bar will work just fine.
Old Jun 26, 2008 | 03:09 PM
White97's Avatar
White97
I just patched mine from a 1974. I cut out the section from the donor, cut out the bad, and welded in teh patch, then I ground, and ground, and ground Can't see any patch lines. If it's not in my gallery I'll post tonight.
Old Jun 27, 2008 | 05:44 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
dotcentral
When you start cutting and grinding be careful of the ****VIN**** its on
the pass side front frame rail, I don't think you should'nt be back quite that far back cutting and grinding but I know a leaking battery does a job on the
frame there too!
Wally Womack
Old Jun 30, 2008 | 06:50 AM
White97's Avatar
White97
I was very careful around the numbers, there was also a stamping on the drivers side.
Old Jun 30, 2008 | 08:28 AM
Pro-Street/StateTK
White97
I'm thinking that the number that you are seeing on the drivers side would be
on the side of front rail right below where you would be cutting, and it is a
part number stamped with real big letters, but I would'nt want to lose those
numbers either!
Wally Womack
Old Jun 30, 2008 | 08:30 AM
dotcentral's Avatar
dotcentral
I didn't think about the vin, but to be honest the frame was pretty much gone for about a 2" wide section. If it was there it was rusted away.
I found some scrap metal of about the same thickness, used a cut off wheel to remove the rest of the thin area and square it up, and welded in my patch. I'm pretty happy with the results. I will need to go back and drill a hole for the radiator support mounts & bushing.
truckerdead
13
Sep 10, 2013 10:01 PM
Samsn4
Sep 28, 2012 09:29 PM
shorttop50
Feb 16, 2005 07:54 PM
cjcathey2002
Aug 15, 2002 06:18 PM
StockMan
Aug 2, 2002 11:46 AM
