so heres my problem went up to sacramento to pick up a falcon truck made the trip like a champ so i went to the store today and its dripping coolant looks like its coming from the waterpump
Make sure you look, because several of us have had a problem with the lower radiator hose, where the the pipe connects to the water pump. You may just need to get some sealant or make a gasket. WHen you crawl under, it will be on your left, while looking up. THe weep hold is dead center of the water pump. Niethger jobs that bad.
If it is water pump replacement time, here's an article that I bookmarked a while ago that has a step-by-step with pics. Luckily, I haven't had to use it yet but you never know...
My truck is dripping from the lower hose, where it bolts to the water pump. Bolts are tight, I just can't bring myself to drop the $50 bucks on replacment anti-freeze to replace a $2 o-ring....
