Low turbo boost code
Old Jun 25, 2008 | 09:18 PM
Tore's Avatar
Tore
I dropped off my truck with an engine code. They said it was low turbo boost.
What is it and what causes it. Thanks Tore
Old Jun 26, 2008 | 07:25 AM
69cj's Avatar
69cj
PO299 and your turbo is probably rusted or coked up/ Mine was just replaced for this.
Old Jun 26, 2008 | 10:01 AM
Tore's Avatar
Tore
What causes that?
Old Jun 26, 2008 | 01:01 PM
OZX1's Avatar
OZX1
Originally Posted by Tore
What causes that?
Lack of use is the #1 cause. If you don't drive the truck enough, or when you drive, you don't kick it in the pants to exercise the VGT, then the vanes will rust-up and stick in one position. It's a known issue...
Old Jun 26, 2008 | 02:42 PM
Tore's Avatar
Tore
Its odd that it threw a code as I was pulling away from a fuel station. And I was on my way home from 1200 mile trip pulling a trailer. I dont use the truck as a daily driver but when I am towing I am right into it . Tore
Old Jun 26, 2008 | 03:07 PM
OZX1's Avatar
OZX1
It's the #1 cause, not the only cause. Maybe it just got tired and failed... You mention that you just got fuel headed home after a long tow... Did you come in (do you usually come in) from pulling and shut-her down before you let the EGT's drop down to ~=350*F? If not, you may have also just fried the turbo... There's a lot of guesswork with a single code.
What year is your truck?
Old Jun 26, 2008 | 03:14 PM
69cj's Avatar
69cj
My truck was running fine, I just happened to throw the code reader on it for the he** of it and up popped PO299. Took it to the dealer and they put a new turbo on it. Can't tell the diference from before or after.
Old Jun 26, 2008 | 04:21 PM
Tore's Avatar
Tore
The truck is an 07 with 19K on it. When I got fuel and the light came on I had to drive thru a small town to find diesel so I dont think it was very hot.
As far as frying the turbo its runs damm good if I did. I will find out how it works Sunday as I am to go pick up a trailer quite a ways away. Tore
Old Jun 26, 2008 | 04:26 PM
OZX1's Avatar
OZX1
Maybe it was just a fluke... You never know with a 6.0!
