Front Right Tire Wearing odd
Old Jun 25, 2008 | 06:26 PM
jbilliel's Avatar
jbilliel
So tonight I was out working on the truck getting it cleaned up as I am hoping to find a new home for her. Saturday I am going to put on new front brakes and rotors to fix the death shake, but I noticed that the right front tire is wearing the inside out. I also have a shake above 55 MPH that will not go away so I am sure they are related. My tire pressures were 65 PSI all the way around. the left front tire looks great!
So I thought that perhaps the hubs was stuck on that side. I checked and it is not. So any ideas?
Is the truck was toed in or out, I would expect the left side tire to be wearing the same way.
Any thoughts?
Old Jun 25, 2008 | 07:58 PM
JAshc511's Avatar
JAshc511
Have you checked your wheel bearing on that side? Raise that corner and grab the tire at 12 and 6. If you can wiggle the wheel and tire, you probably need a new wheel bearing. If that is the problem, you have to replace the entire assembly, which makes it more expensive, but the benefit is that it is only 4 bolts (after you get the brake caliper off and pull the sensors plugs).
Old Jun 25, 2008 | 10:58 PM
rebelyell618's Avatar
rebelyell618
along with the wheel bearing (as stated above) it could also be the upper and lower ball joints.
Old Jun 26, 2008 | 07:50 AM
jbilliel's Avatar
jbilliel
Hmm... I gave it a good tug and it seems ok. The truck was at the dealer just a couple of months ago to check the ball joints out.
Old Jun 26, 2008 | 07:59 AM
Brians97F250Crew's Avatar
Brians97F250Crew
yea my first thought was ball joints
Old Jun 26, 2008 | 08:41 AM
rebelyell618
if the wheel doesn't wobble when you have it off the ground lifted by a jack then i would look into it being a bad tire or the tire is out of balance.
that would give you a vibration and tire damage with nothing being wrong with the trucks steering components.
plus a front end alignment wont hurt either.
Old Jun 26, 2008 | 03:23 PM
jbilliel's Avatar
jbilliel
Ok I will pull the tire off and give it a good once over. Thanks guys!
Old Jun 26, 2008 | 03:40 PM
seventyseven250's Avatar
seventyseven250
rotate your tires and watch the wear on that corner, and whichever corner you swap that tire to.
If the uneven wear happens again on that corner, you know it's not the tire.
If the wear continues to be uneven on that tire in it's new location, it's the tire.
good luck.
