Unplugged EGR Valve
Old Jun 25, 2008 | 02:50 PM
jmaskew's Avatar
jmaskew
Unplugged EGR Valve
For the last 800 miles or so I ran with the EGR Valve unplugged. The most obvious thing I noticed was Boost. With the valve unplugged the highest I could get it to boost was about 25psi. I didn't tow during this time. It seemed more responsive... less turbo lag. No difference in fuel mileage. This morning after I plugged the EGR valve back in I noticed an immediate change in boost as I hit 29 psi with noticeably more power at the high end. I was expecting the exact opposite. Anyone else have similar experiences after they unplugged their EGR Valves?
Old Jun 25, 2008 | 06:59 PM
rollerstud98's Avatar
rollerstud98
I know I've had mine unplugged for some time now, and only see about 24 psi of boost, don't really want to plug it back in to bad as its been unplugged for a year or so now
Old Jun 25, 2008 | 07:14 PM
jmaskew's Avatar
jmaskew
I thought about unplugging it today and leaving it that way but I don't know what's worse; hot exhaust passing through the EGR Cooler or hot exhaust just sitting inside with no where to go. Until it's blocked off I think I will leave it plugged in.
Old Jun 25, 2008 | 08:57 PM
cartmanea's Avatar
cartmanea
If you unplug the EGR there is nowhere for the exhaust gases to flow, so less heat will go into the cooler. It will still heat up, but nowhere near as hot as it would get with exhaust flowing through it. Mine has been unplugged since I cleaned the EGR and turbo a few months back, never getting plugged back in.
Old Jun 25, 2008 | 10:27 PM
jmaskew's Avatar
jmaskew
Thanks Cartmanea for clearing that up. Do you notice a drop in turbo boost also?
Old Jun 25, 2008 | 11:10 PM
cartmanea's Avatar
cartmanea
I don't have a boost guage, but I didn't notice any change in performance.
Old Jun 26, 2008 | 09:23 AM
Lead Head's Avatar
Lead Head
Just a theory, but your increase in boost might actually be the exhaust gasses adding additional pressure to the intake?
Old Jun 26, 2008 | 11:28 AM
cartmanea's Avatar
cartmanea
I think that's true. The much hotter exhaust gas expands with heat and creates high pressure.
Old Jun 26, 2008 | 12:19 PM
tttario's Avatar
tttario
The reason for your boost changes is that when you unplug the EGR, the computer changes programming and the turbo's variable vanes are set to a default position and do not move. Result being higher boost on low end and lower boost up top. When the vanes are allowed to move they can spool the turbo faster and provide higher boost up top. I seen similar numbers on my boost gauge under similar circumstances.
Cheers.
Old Jun 26, 2008 | 12:41 PM
cartmanea's Avatar
cartmanea
Cheers.
I'm pretty sure this is not true. Some '05 and newer trucks, especially CA trucks will go to a limited performance mode where it affects the fuel injection, but the turbo is not affected as far as I know.
Old Jun 26, 2008 | 12:56 PM
OZX1's Avatar
OZX1
Nope... tttario is correct. The VGT goes into limp-mode for the sake of survival. The PCM depends on signals received from all monitored engine and emissions components. If a major player is disconnected without being removed from the strategy, the PCM responds by trimming the VGT to a static, or limp-mode. Fixed amount of boost across the RPM range.
Old Jun 26, 2008 | 12:57 PM
jmaskew's Avatar
jmaskew
Cheers.
It would seem the turbo would stand a chance of the veins sticking in the default setting if the egr is unplugged for a long time. I guess it would be a safe position to be stuck in. I definitely noticed lower power on the top end while I had it unplugged.
Old Jun 26, 2008 | 07:51 PM
zss42002's Avatar
zss42002
I have installed a EGR delete which consists of EGR Cooler bypass basically and a new uppipe with blocked of egr. I didnt dissconect my egr valve but i am throughing codes ie. insufficeient gas flow/ recirculation flow low. My guess is the turbo has gone into lymp mode?? and i am not seeing high amout of boost. relly low like 15. it iwill go about 22 going up hill but on striaight away WOT only go to about 18. If turbo has gone into lymp mode how can i change this?? I have a X3 custom tunes with egr bypass i guess the CEL went out but boost is not good? Any suggestions or is my theory correct??
Old Jun 26, 2008 | 07:59 PM
npccpartsman's Avatar
npccpartsman
And if anyone has noticed when cleaning an EGR valve, it takes very little effort to open it by HAND. Enough boost and it will blow open anyway. Unplugging the EGR valve without a delete modification to shut off exhaust to the cooler will cause you nothing but problems. It will still get very hot. The best method is to drive it HARD to try and keep it clean and don't let it idle for extended periods.
and YES......unplugging the EGR valve causes the PCM to go into a default mode which limits boost to the turbo. You've changed operating parameters by unplugging the valve so the computer compensates accordingly.
Old Jun 26, 2008 | 08:01 PM
OZX1's Avatar
OZX1
Is your current tune written to ignore, or factor out the EGR status from the scheme of the tune? That's the trick... The EGR cannot be a factor to the PCM or it'll cause the truck to go stone wacky. This I report from personal experience and vicarious experience. I neutered my truck with the EGR unplugged, and it ran like a Geo Metro on the freeway... Just no snap. There are posts--somewhere in the 6.0 forum--by resident techs attesting to this same "limp-mode" phenomenon.
Yeah! What Tim said!
