what should I do next?
. Any suggestions on what I should do next? I think I want to add a mini-disc changer(if I can afford one) and then spend preferably less than $200 dollars on amps/whatever else I need. I would like to stay with Sony or Pioneer for everything since they seem to be pretty cheap, and their quality is good enough for my ears. What kind of amp should I look for? can anyone explain just what any of the rateings on a amplifier will mean, I pretty new at this? Or what are "average" specifications, what should I look for?
Thanks, Logan.
>52 x 4 watts(23.2 RMS
>watts according to Crutchfield), two
>2 volt preamp outputs, but
>no specific sub-woofer preamp outputs.
>For my speakers I
>have Pioneer TSA-1663(6 1/2in 3
>ways) and Pioneer TSA-6865(6x8in 3
>ways) Both rated up to
>180 watts, but their nominal
>power is 50 watts. I
>think I mihgt be able
>to get a great deal
>on some Pioneer 12inch speakers
>because a freind bought them
>but apparently cant install them
>do next? I think I
>look for?
>Thanks, Logan.
Logan,
Trying to get subs and an amp for under 200 probly won't happen. and if it does, you won't be happy with the results. Do you want to run your pionner 6 1/2's and 6X8's off an amp. A nice 4 channel amp would work good in this situation. Of course you could always run these speakers off the deck and get a nice mono amp to run your subs off of. You will however have to shell out some kind of money to get subs and an amp. You may want to look at increasing you budget by 100 to 200 dollars to get quality peices.
Good Luck
Murph
), so I think I'll hunt for a 50-100 watt amp.Logan
with continouw 50W x 4, and max of 100W x 4(at 4ohm of course), but I think I can get a higher power amp for nearly the same price if it 2 channel. Won't I most likely have to get a 2ohm stable amp if I reun them parallel/in series? What about the power directed to each speaker, would it be cut in half or stay the same(excpet with a higher load if I don't wire everything right?). Thanks for helping me a lot, but I think I will have nearly a million questions about the 2 channel for 4 speaker idea, and I will check on more info for the 12 inch subs that I might be able to get.
Logan
Logan
The lack of subwoofer-specific RCA outputs in the deck is really nothing to worry about, the only thing they do is allow you to use a crossover integrated into the deck, and you can turn them on and off remotely. Nothing especially important.
If you go with the Pioneer, I'm sure it has all this, but some things to check for: Make sure it has 2 crossovers in it, one for each pair of channels. You may not choose to use a crossover on your highs, but you must have one on your sub or subs. It should have full range, high pass, and low pass, and preferably some way to adjust the frequency cutoff. If it does not have one you will have to get one separately. Make sure it is bridgeable, because that is how you will want to hook up the sub. Bridging is a way of combining two channels of an amp into one, with a net power gain. If your amp was rated at, say, 50 watts X2, it might put out 150 watts X1 bridged. The amp's instructions will tell you how to bridge it. I would go with only one sub, because you won't have enough power to really take advantage of the second one, and this way you will have a little more room in the cab.
If you decide to go with a 2-channel amp, you will be forced to devote it exclusively to your sub or subs and run the other speakers off the deck. This will cost a little less, and it may be a better option considering your budget. Also the wiring would be simpler, as hooking up the other speakers is kind of a PITA anyway.
It all depends on what you want.
sorry, this post looks kinda stupid. I was writing when the last message was posted.
