VIN Decode
Old Jun 24, 2008 | 08:31 PM
th1567's Avatar
th1567
VIN Decode
Hello, Tim here....
What I need help with with is a deciphering of the following Door Tag info..what I have here is two trucks...truck 1 seems pretty much stock..truck 2 has had several mods...like power steering of a 73~ and a/c off a who knows what.....also has 390 heads w/Galaxie intake...anyways here goes...
TRUCK 1
ID: F25 YR 834796
WB - 129
COLOR: blank<<<<IT'S SOLID AQUAMARINE, no white
BODY: B81
TRANS: A
AXEL: 24
DSO: 721797
TRUCK 2
ID: F25 YR 748285
WB - 129
COLOR: M
BODY: C81
TRANS: G
AXEL: 24
DSO: 71
th1567 drives a
66 F250 352 2BBL W/NP435
66 F250 352/390 4BBL W/2 SPD CRUISE O MATIC
70 F250 W/360 2BBL W/3 SPD MANUAL
95 ASPIRE 3.5 CYLINDERS & .001 HP GET 35 MPG
02 TAURUS WAGON PLASTIC BANANA JELLY BEAN ANTI AFFAIR DEVICE
Old Jun 25, 2008 | 09:10 PM
Customcab's Avatar
Customcab
I will try and decode what i can and i'm sure others can do better; I'm using and old FTE decode chart i got from here back several years ago.
TRUCK 1
ID: F25 YR 834796
F25= F250 2wd
Y= Engine 352 V-8 2v
R= assembly plant San jose
834796= assembly date Mar 1966
WB - 129 = Wheel base lwb
COLOR: blank<<< BODY: B81= Customcab
TRANS: A= 3spd Manual
AXEL: 24= 4:10 ratio
DSO: 721797
TRUCK 2
ID: F25 YR 748285
F25= F250 2wd
Y= 352 V-8
748285+ assembly date Sep 1965
WB - 129= wheel base lwb
COLOR: M = Corinthian White
BODY: C81 = customcab
TRANS: G= Cruiseomatic
DSO: 71
hope this helps; other will correct any short falls on my behalf.
Mitch
Old Jun 25, 2008 | 09:57 PM
th1567's Avatar
th1567
And I thank you....NumberDummy produced similar results...very helpful...
TH1567
We pulled out and moved down the old Hiway 66...in an 86 F250...no regrets as the sun sank behind us..December 1986
DangerBoyForty
Sep 14, 2013 02:11 PM
hammer 64
Sep 24, 2007 02:39 PM
hammer 64
New Member Introductions
Sep 17, 2007 09:08 PM
lance65
Jan 15, 2007 12:31 AM
