It might be better if you explain your problem along with your findings, this way we can help you better.
The cable going from the battery to the solinoid it hot all the time, the cable going from the solinoid to the starter is hot only when you turn the key to start. The starter is grounded by it's mounting bolts. Your test light will most likely light up doing what you did above but I've never tried doing that.
ok u explained everthing very good my promble is that the starter will not do anything but i get power to everything but the starter wire after the solinoid
