starter help
Old Jun 23, 2008 | 09:19 PM
dopeys4x4's Avatar
dopeys4x4
Angry starter help
should the starter b grounded at the wire going from the relay to the starter
Old Jun 23, 2008 | 09:37 PM
4x4 Bart's Avatar
4x4 Bart
You will have a hot wire from the starter solenoid (on the Fender) to the terminal on the starter.
Old Jun 23, 2008 | 09:45 PM
dopeys4x4's Avatar
dopeys4x4
ok so when i took a test light from the + side of the batt to the wire coming off the starter it lights up is that right or do i have a bad starter
Old Jun 23, 2008 | 10:26 PM
OldMetal's Avatar
OldMetal
It might be better if you explain your problem along with your findings, this way we can help you better.
The cable going from the battery to the solinoid it hot all the time, the cable going from the solinoid to the starter is hot only when you turn the key to start. The starter is grounded by it's mounting bolts. Your test light will most likely light up doing what you did above but I've never tried doing that.
Old Jun 23, 2008 | 10:39 PM
dopeys4x4's Avatar
dopeys4x4
ok u explained everthing very good my promble is that the starter will not do anything but i get power to everything but the starter wire after the solinoid
Old Jun 24, 2008 | 02:59 AM
ford4604bbl's Avatar
ford4604bbl
Have you tried jumping across the seliniod to see if the stater works? Sounds like a bad seliniod to me .
Old Jun 24, 2008 | 08:02 AM
gilllawn's Avatar
gilllawn
You have a bad solenoid
Old Jun 24, 2008 | 09:42 AM
daddy172005's Avatar
daddy172005
Solenoid is bad.
Old Jun 24, 2008 | 04:50 PM
dopeys4x4's Avatar
dopeys4x4
thanx ull rhat helps alot
