Changing the differential gear
Old Jun 23, 2008 | 02:12 PM
roboteacher's Avatar
roboteacher
My son works at a garage and his lead mechanic said they could change out the gear in my 2000, 4.6 2WD to increase my fuel efficiency. He said I would lose my low end but I literally do no towing. They say they can do this for around $200.00. Is this for real and is it worth the $200.00?
Old Jun 23, 2008 | 03:12 PM
85e150's Avatar
85e150
The gears alone are $200, recheck that quote.
Old Jun 23, 2008 | 03:31 PM
berry1234's Avatar
berry1234
What kind of gains can this realize?
Old Jun 23, 2008 | 05:50 PM
pitrow's Avatar
pitrow
probably not enough to be worth it. You could swap your gears out for better highway economy, but you'll do it at the expense of economy at the stop lights.
So, you'll lower your RPMs at freeway speed for better economy, but you can't get something for nothing, so your engine will work harder trying to get started from a stop. If you do the majority of your driving on the freeway with relatively few hills, you might be able to gain 3 or 4, maybe even 5 mpg, but don't expect this to be a magic bullet.
BTW, $200 does seem awful cheap.
Old Jun 24, 2008 | 12:06 AM
85e150's Avatar
85e150
What gear do you have now?
What transmission and what is you OD ratio?
What gear are you thinking of changing too?
Jacobs Daddy
Oct 31, 2013 12:03 AM
tims01
Jan 19, 2012 08:20 AM
mach2race
Oct 30, 2006 11:03 PM
bigred94
Electrical Systems/Wiring
Nov 21, 2002 06:41 AM
