Sponsored by: Auxito
Engine and Transmission swap
Old Jun 21, 2008 | 07:35 PM
Hillbilly_Deluxe's Avatar
Hillbilly_Deluxe
Hey. I have a 99 f150 4x4 that needs an engine. anyway i found a parts truck with a good engine and a 5 speed tranny for $700. I would also like to swap my auto for the manual the only thing is the parts truck is a 2wd. does anyone know what I will all need to do this? Is the output shaft different on the 2wd transmission? will the computer from the 2wd work on the 4x4? will the pedals, master cylinder etc. all bolt up? what about the steering coulum? any thing else? the parts truck is a 97 if that makes a difference.
Thanks
Jeremy
Old Jun 21, 2008 | 08:50 PM
Bobby82490's Avatar
Bobby82490
If you ever tow with your truck, i wouldnt install the 5 speed that comes with these trucks... they are weak.
Old Jun 22, 2008 | 10:39 PM
Hillbilly_Deluxe
I am aware of that. thanks anyway. Anybody have any ideas?
Old Jun 22, 2008 | 10:53 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
i can tell you the output shafts are different. good luck with this swap... may i ask why you think the manual is a better option than the auto if your not towing?
Old Jun 23, 2008 | 07:16 PM
Hillbilly_Deluxe
Hey, thanks for the reply. Its probably not the better option but I prefer driving a manual over an auto.
Old Jun 26, 2008 | 12:02 PM
fordinlinesix's Avatar
fordinlinesix
i would measure the length of the tranny from the front to the rear of the output shaft, it it's the same I think all you have to do is unbolt the tailshaft and the transfer case assembly should bolt onto where the tailshaft cover was. Make sure you grab the pedals and the hydraulic clutch stuff. You will also need to grab the manual transmission wiring harness. It bolts onto the firewall on the passenger side, just swap it with your automatic wiring harness. You might also have to grab the computer from the 2wd since it will be programmed for a manual, I'm not positive on that though.
Tinterat
Apr 17, 2022 05:02 AM
ROBZ95XJ
Apr 22, 2012 09:13 PM
sverker
Nov 12, 2011 06:03 AM
OldIronNut
1983 - 2012 Ranger & B-Series
Aug 20, 2008 11:00 AM
m000996
May 2, 2008 01:41 PM
