Sponsored by: Auxito
electrical problems
Old Jun 25, 2008 | 07:06 PM
spankyrir's Avatar
spankyrir
electrical problems
i'm having a number of problems. first of all every sensor on the engine seems to be bad, according to the OBD2 tool. and the a/c seems to be bad. i can't believe every sensor would be going bad all at the same time. i suspect an electrical problem. if i have a bad ECM would that cause the issues?
Old Jun 25, 2008 | 08:40 PM
fireball 440's Avatar
fireball 440
...a bad scan tool maybe? If every sensor was shot the engine would not run. Possibly check for a loose/bad ground for the PCM or DLC.
Old Jun 25, 2008 | 09:42 PM
AzBlueWolf's Avatar
AzBlueWolf
check battery terminals for corrosion,loose fitting
perform a voltage drop test at all the grounds
got an alarm...or sound system...inspect the wiring
wiggle the key while scanning the pcm
Mark
Old Jun 26, 2008 | 03:33 PM
eallanboggs's Avatar
eallanboggs
How the heck did you determine every sensor is bad? I wouldn't play the Powerball anytime soon with that kind of luck.
