Trailer brake controller wiring questions
Old Jun 21, 2008 | 12:10 AM
hoof's Avatar
hoof
Other than losing the manual function and the on the fly adjustment, both of which I very rarely used, is there any reason I can't mount my trailer brake controller at the rear of my vehicle?
Can I simply use the stop light wire from the trucks four flat connection to trigger the brake controller instead of a wire right from the brake pedal switch?
This would make installing the controller SOOO much easier.
Thanks,
CHAZ
<!-- / message --><!-- sig -->
Old Jun 21, 2008 | 07:33 PM
sawfish99's Avatar
sawfish99
What truck are you installing it in? I know SDs have a quick connect under the dash, so that is easier than splicing wires. I wouldn't put one outside the truck, because the electronics won't stand up to the weather. Also, the controller inside the cab will give you indication that you still have a good connection to the trailer. If the trailer is heavy enough to need brakes, I wouldn't cut corners on the install.
Old Jun 22, 2008 | 01:12 PM
Steina's Avatar
Steina
CO River Rat
If you ever need to jerk a swaying trailer back into line, you want that manual slide where you can get at it QUICK.
Steve
Old Jun 22, 2008 | 07:57 PM
grafekie's Avatar
grafekie
Just put it in the cab All late model (1998+) Ford trucks have the wiring installed already.
Old Jun 26, 2008 | 06:56 PM
Beerstalker's Avatar
Beerstalker
I highly doubt that the controllers are sealed up good enough to withstand the dirt/dust/water that it would encounter if you installed it at the back of the truck.
It really isn't that hard to install one on most vehicles.
Old Jun 27, 2008 | 09:38 AM
spidermonkey's Avatar
spidermonkey
just a side note...my 94 had the quick connect under the dash, right under the power point. But the Blue wire that SHOULD go all the way back to the rear bumper, only went as far as the firewall connector that is left of the brake pedal. The blue wire goes into the connector, but there was no wire in the mating slot on the engine side of the firewall. So I had to splice in from there and run the blue wire (to actuate the trailer brakes) to the rear bumper.
All that to say, just because you find the quick connect and your brake controller does power up, doesn't mean the wiring runs all the way to the back.
Kind Regards,
Old Jun 27, 2008 | 02:53 PM
grafekie's Avatar
grafekie
In new trucks (1998+) its wired all the way to the rear of the frame, where the rear light harness hooks into the main harness. You just have to tap in above the left rear tire and you are good to go!
