Ok so I pulled the driver side VC hoping to see some chaffing loose plug or somthing to identify the problems im having. No such luck. So correct me if im wrong but the arm that is at the end of my connecting rod is the rocker arm, and that arm on a few rods can move side to side a good but. Some were tight with no movement at all, others moved nearly an 1/8 inch side to side. What kind of future damage or current problems could this be causing?
PS Early 99 f250 260k
Not being nit picky but that would be a pushrod not a connecting rod at the rocker arm. The tension on the rocker arms is in direct relationship to what valves are opened or closed at the time the engine was shut down .The valves that are opened completely will be the tightest down to the ones that are closed being loose and wondering if something is wrong. I would go ahead and re-torque the hold down bolts like allready mentioned
I don't even know whether we have solid lifters or hydraulic. With solid is there not some valve lash required? But with hydraulic there would be zero lash and only then would just torqueing them work. I have no business getting involved here......LOL..I don't have a clue how the valve train works as I've never even seen under one of our valve covers. Hope it stays that way. Is there a rocker arm shaft, or is each rocker on its own pivot point?
Doing mine today as soon as i get my coffee
After some searching around i found a thread with Dan ( kwikordead ) giving us the torque.
20 foot pounds on the rocker pedastals, four bolts per pedastal. (also as jim has stated)
Also check injectors while your there.
120 INCH pounds on the lower bolt holding the injector in.
yea it started getting dark out and i was afraid of rain hitting, so i closed up before i could get to the injectors. That and i usually carry my laptop down to have you guys at close hand if i get lost somwhere and i didnt have it ready either so. But i will be keeping you guys in check this afternoon, im picking up a scanner from my dad to see what the computer says is wrong. Im convinvece that my CEL donest work, never seen it come on and the truck runs like garbage, and no i have a massive powersteering fluid leak. As soon as i pour it in it comes right out, almost of the drivers front wheel. (in the whele well) Anyways off to a baby shower! wahoo! thanks again guys your the best! Steve.
Steve. Keep an eye out where that fluid is going. Your IDM is inside the drivers front fender above the wheel well. If you get water, or any other kind of fluid on the IDM it can cause your truck to run bad.
rrrrreally, that is very helpful info my friend. Tomarrow im going to tear in there and see what i can take alook at. Any photos of this IDM so i can identify and check working condition. Can I do a test on it as well?
This is actually instructions on how to mod the IDM, but it will show you where it is and what it looks like. I don't know of any way to test one, but have heard of a few who could hear water sloshing around inside theirs if they shook it. It's basically wires & circuit boards so it doesn't play well with fluids.
Didnt read much of the thread, but the valves do not get adjusted, the engine oil pressure inside the hydraulic lifters keeps constant valve lash, i'm assuming it's .000" or damn close to it, but it is "soft", only held there by oil pressure. The camshaft pushing on the lifter pushing on the pushrod directly relates to if the valve has tension on it or not. The cylinders not currently on a valve cycle do not have any side to side pressure on the rocker arm.
