Aerostar Ford Aerostar
Heater hose order?
Old Jun 20, 2008 | 05:52 AM
Zen Punk's Avatar
Zen Punk
Heater hose order?
93 aero 3.0l no auxiliary heater
Which heater hose goes to which fitting(top or bottom) on the heater core? I just replaced it but I didn't check beforehand and I cant find out what it's supposed to be.
There's one that attaches to the water pump, and one that goes to the thermstat housing. Is there any kind of structure inside the heater core that would make it easier to flow one way?
p.s. Anyone know which way the water flows through the water pump? In through the lower rad hose and out through the heater hose or is it the other way around?
Old Jun 20, 2008 | 11:53 AM
xlt4wd90's Avatar
xlt4wd90
I don't think it matters much which port on the heater core you use as inlet vs outlet. On some cars, the hose from the pump has a flow restricter in it to reduce the shock of the water pulse going to the core. This is the only thing you need to keep in the right hose, but again, which port on the core that goes to does not really matter. Similarly, some heaters have a valve that shuts off water flow, and again, you need that on the hose coming from the water pump.
Old Jun 20, 2008 | 02:07 PM
Bear River's Avatar
Bear River
Former ******
Actually, it does matter, if you hook up the hoses wrong, air will get trapped inside, hindering cooling efficiency. I am sure the inlet is the bottom, and the outlet is the top. I have not replaced the heater core, so don't quote me on that.
Old Jun 20, 2008 | 04:19 PM
xlt4wd90's Avatar
xlt4wd90
That makes sense...but by "cooling efficiency", do you mean "heating efficiency"? That's the main purpose of the heater core, as it does very little to cool the engine.
It just occurs to me that maybe I hooked up mine incorrectly, as I always hear air bubbles gurgling through it. It seems to provide plenty of heat though. I'll have to check, and now it's an easy enough fix.
Old Jun 21, 2008 | 08:05 AM
ridgerider3's Avatar
ridgerider3
Most heater cores have both inlet and outlet in the same spot.
A "Old School" trick to flush and get the heater core working again is to switch the hoses to reverse the flow to break the crud loose.
Ford is also good for making the inlet and outlet hose different sizes just to pi$$ you off and have to but 2 separate hoses instead of one long piece.
I haven't looked real close at my Aero, but I will try to get a few pix's and post them on my Webshots to help you out.
Old Jun 21, 2008 | 01:53 PM
ridgerider3
Pictures are uploaded.
http://community.webshots.com/album/563870481KNkaNc
Hope they help ya.
My finger is on the "top" hose which goes into the bottom of the heater core.
Last edited by ridgerider3; Jun 21, 2008 at 01:55 PM. Reason: Won't let me add pictures
Old Jul 31, 2008 | 06:34 AM
fmshea's Avatar
fmshea
So it appears the bottom Hose on the water pump is the thermostat bypass? Judging by the photos...
I replaced my water pump on my 91 lariat and am trying to figure which hose goes to which tube...
