A lot of guys use the gallery here and then link to them I guess. I use Photobucket and then I use HTML coding to link to the URL like this:
[img]URL goes here[/img]
You do that and the photo will be in your post.
I use the gallery to post mine. I don't type in the HTML coding, I just have the picture open in a separate window or tab, right click on the picture and select copy image location. Then in this reply window (can't be the quick reply - needs to be the go advanced option) I click on the button at the top of the box and just paste the copied info there and hit ok. The button looks like an envelope with a stamp on it to me, but if you hold your mouse over it, it does say insert image.
Mine is not max size, 500 x 120 is max and mine is only 300x120. You should be able to go much bigger than what you have. Upload it to your gallery then copy and paste from there.
