96 p401
Old Jun 19, 2008 | 12:46 PM
3rd car's Avatar
3rd car
Exclamation 96 p401
hi i am new here but i have a 96 explorer v6 4.0 i have been putting a lot of money in my car and i am ready to get rid of it if i cant get it fixed i had a coolent leak in the intack mani gasket did that about 2 days later get a check engine light all 3 o2 sensors waited a while on that then i get rough idle so i fix all 3 sensors still bad idle so i get the code re3ad agin p402(exessive egr flow) so i get a new egr clear codes and still same problem so as i am messing with it when i take vacume line off good idle but now i have a p401 so the problem is the vacum line is holding the egr open what the hell controld the vacum i am only 18 working and trying to afford gas in ny and this car is killing me i need help please anything is greatley appricated
Old Jun 19, 2008 | 01:12 PM
Milisivana's Avatar
Milisivana
I had the same error code of excessive egr overflow. I tapped on the cover of the egr and it must have unclogged whatever the problem was because my check engine went off. I'm not going to mess with it unless I get the check engine light again.
Possible your vacuum line is clogged?
Old Jun 19, 2008 | 02:34 PM
3rd car's Avatar
3rd car
but my vacum line has constent suction so i would doupt its clogged
Old Jun 19, 2008 | 07:55 PM
danr1's Avatar
danr1
Wow rash of 0401 codes, just had the same one myself.
See,
https://www.ford-trucks.com/forums/751691-96-ford.html
2oo1 4x4
1997 - 2003 F150
May 15, 2014 08:05 PM
Godfrey08
1997 - 2003 F150
Nov 16, 2010 08:08 PM
RGrimes
1997 - 2003 F150
Feb 7, 2006 12:36 PM
keld
Jan 7, 2005 06:46 AM
ewellman
Sep 30, 2003 12:01 PM
