Sponsored by: Real Truck
Installed Another Homelink (pics)
Old Jun 19, 2008 | 01:13 AM
05lariatPSD's Avatar
05lariatPSD
Smile Installed Another Homelink (pics)
OK guys...I installed another Homelink. This time in my 2008 SD.
I had the forethought this time to take pictures to document the install for those of you who want to give this a try.
While this install is on an 08, the procedure has been the same since the 1st one I installed on my 2000 Expedition.
I picked up this unit on eBay for about $30. Try to locate a complete visor from any vehicle (doesn't have to be a Ford) instead of the module alone. Look for the module with the LED that looks like a house for the rolling code module.
Alright then...here we go:
After removing the visor and unplugging the power, begin by starting to pull the fabric carefully from the seam. I use a butter knife to slightly separating the halves of the visor.
After you've gone all of the way around, you will have exposed the installation area:
Here I have the buttons separated from the module. Just carefully pry the tabs to remove the buttons and the button cover:
Next I removed the vanity mirror to determine the positive and negative wires to the mirror light. Here you can see that I marked them to make it easier to wire the module up:
Cut out the pre-scored area and install the module after wiring (you may want to temporarily plug the visor in and press the buttons on the Homelink to ensure that your wiring is correct before popping the module in):
I like to use a credit card to re-insert the fabric:
Visor back together. Now you'll want to carefully cut a slit to pop the buttons and cover back on:
That's it!!! Now just re-install the visor and program the module. You can find the programming instructions at
HomeLink; Home automation,Wireless control system, universal transceiver, RF control, Home security, smart home, vehicle to home, home automation, remote control lighting and home control
Old Jun 19, 2008 | 08:16 AM
03_PSD's Avatar
03_PSD
thats pretty cool.
Old Jun 19, 2008 | 08:31 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Reputation points for contributing to the community!
Thanks!
Old Jun 19, 2008 | 08:56 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
OK, here I go. What are the buttons for?
Old Jun 19, 2008 | 09:00 AM
05lariatPSD
Well...Think of Homelink as a factory installed universal remote for your garage door(s) and/or gates.
It eliminates having openers clipped to your visor and works with different garage door opener manufacturers.
Many different auto manufacturers install it as a factory option, but homelink does not sell it aftermarket, so you have to get one from eBay or your local pick-a-part.
I use mine for my 2 garage doors and the remaining button is used for my community gate.
Old Jun 19, 2008 | 09:13 AM
NorCalBusa's Avatar
NorCalBusa
Nice job and excellent documentation!
Old Jun 19, 2008 | 10:07 AM
miller_feed
Thanks for the explanation. I was kind of thing towards that but didn't know for sure. You did a great job with the install.
Old Jun 19, 2008 | 09:01 PM
jake00's Avatar
jake00
this needs to be a tech article
Old Jun 19, 2008 | 10:51 PM
GPNJPSD's Avatar
GPNJPSD
Very cool, thanks for the great info, all I need now is a garage door.........
Old Jun 19, 2008 | 11:26 PM
NorCalBusa's Avatar
NorCalBusa
Does the ignition key need to be on for that to work? Seems like it should- since it'll be parked in the damn driveway and not doing so would give the bad guys easy access to getting themselves shot coming in the house via the garage...
Old Jun 19, 2008 | 11:28 PM
jake00's Avatar
jake00
it'd be no less secure than a door opener sitting on your visor
Old Jan 10, 2009 | 06:09 PM
gottarun's Avatar
gottarun
Just wanted to say thanks for your write-up. Explanation was great. Didn't have to split apart the visor. Popped out the vanity light to gain access to power. Fed the wires from the Homelink to the vanity light through the empty passageway between the light and Homelink.
Carefully tucking in the fabric with a credit card was easy.
Looks factory.
Thanks,
Don
Old Jan 10, 2009 | 06:30 PM
broncobran68's Avatar
broncobran68
Very nice. I might be doing that in the future. However the pics dont work. Any chance you could put them in a gallery or somewhere else that i could see them?
Old Jan 10, 2009 | 08:36 PM
System's Avatar
System
Prolocutor
Photo's not coming up now??
Old Jan 10, 2009 | 08:39 PM
MIKE1646's Avatar
MIKE1646
I cant see the pictures
