Sponsored by: Innova
Premium sound display problems
Old Sep 23, 2001 | 08:26 PM
biglurp's Avatar
biglurp
Hi. I've got a 1998 Mountaineer with the Mach premium sound. The display will slowly fade to dead at times then come back on. It doesn't affect the sound at all,,,it's just annoying..Any thoughts??
Old Oct 31, 2001 | 10:16 AM
cotoole's Avatar
cotoole
I am having the exact problem with a 98 Explorer Limited. With the Dual Media Audio System with CD DJ compatibility. Is this possibly a problem with the wire that dim's the display? Any info greatly appreciated!
Old Nov 21, 2001 | 01:20 PM
tim02062's Avatar
tim02062
I have the same system in a 1998 ford explorer limited. My radio had the same symptoms. Now my display is out totally. The radio works fine, but no display whatsoever, no clock either.
Old Nov 26, 2001 | 06:46 PM
cotoole's Avatar
cotoole
I heard word of a place that you can send the
radio for repair... No details though.. Anyone hear
of such a place?
Old Dec 18, 2001 | 12:41 PM
biglurp's Avatar
biglurp
Is the amp located back by the sub-woofer?
Old Dec 19, 2001 | 09:40 PM
e_no_g's Avatar
e_no_g
The problem has to do with the radio being too close to the heater and ac vents. Im sure when you play a cd for an extended period of time it will come out real hot when ejected. I havent heard of any fix for it, I just bought a new radio and the dash kit that I got with it has a small pocket above the radio opening, taking up the extra space from the larger factory radio. The pocket sits right under the vents so now it blocks it from the radio. No more problems with heat.
Old Jan 7, 2002 | 12:10 PM
djd's Avatar
djd
I have the same problem with my 99 F-150. The best remedy is pressing firmly on the actual display. That works for me.
DD
Old Jan 7, 2002 | 02:03 PM
theleetbeagle's Avatar
theleetbeagle
