Sponsored by: Auxito
tailgate up or down
Old Jun 18, 2008 | 01:15 PM
02Ford150's Avatar
02Ford150
tailgate up or down
Can you get better gas mileage if ya leave the tailgate down?
T
Old Jun 18, 2008 | 01:38 PM
92merc's Avatar
92merc
Not from all the research I've seen. Mythbusters found the opposite. I'd recommend checking that site for your own opinion.
In the end the best thing to affect your mileage is your right foot and how far you press it.
Old Jun 18, 2008 | 01:44 PM
montanafordman's Avatar
montanafordman
Actually mythbusters found the same - that leaving the tailgate down did NOT improve gas mileage - in fact it made it worse! They did a pretty good study with identical ford trucks and were very scientific about their testing and the truck with the down tailgate ran out of gas first every time. They even used die and water to show the aerodynamics of how it worked out that way and with the tailgate UP it had less drag. Pretty interesting show if you can find it!
Old Jun 18, 2008 | 01:57 PM
02Ford150's Avatar
02Ford150
Cool..Thanx.
Old Jun 18, 2008 | 02:08 PM
CampSpringsJohn's Avatar
CampSpringsJohn
If I remember correctly, a bed cover, tonneau cover, hard or soft, helped with better fuel mileage.
Old Jun 18, 2008 | 02:38 PM
Travism's Avatar
Travism
Only drive with the wind at your back yup, saw that MB show. It was pretty interesting. If I remember correctly the one with it up only got about a mile more out of the tank than the one with it down. Turbulence in the bed form the tailgate up caused an air bubble sort of and the oncoming air to flow over it and not cause drag.
Old Jun 18, 2008 | 06:47 PM
crehberg's Avatar
crehberg
Merc hit it right on the head....it isn't so much about tailgate up/down....it is about how far you put your foot down.
Old Jun 18, 2008 | 08:24 PM
mtondreo's Avatar
mtondreo
If I remember correctly, Mythbusters found that the only thing (tailgate wise) that helped was those tailgate nets. But even that was very minimal.
Old Jun 18, 2008 | 08:31 PM
Ultramagdan's Avatar
Ultramagdan
Tailgate up. Leaving it down will cause it to bounce over bumps and it ends up taking quite a beating sometimes.
Old Jun 18, 2008 | 08:39 PM
Piolet's Avatar
Piolet
As well as better mileage with the gate up, I also remember hearing that in the event of a crash, the vehicle may not perform as well without the gate being up. Gate up is how it's designed for crash protection.
I believe I heard that on cartalk so nuff said
Old Jun 18, 2008 | 10:11 PM
galaxie641's Avatar
galaxie641
Plus the rocks that get thrown up and chip the gate. I do wish MB would have run a test with no tailgate, from their little windtunnel tests it looked like no gate would have been just as good as having it up, the extra 1.5' length with it down seemed to be just enough to screw with the air flow.
Old Jun 18, 2008 | 10:15 PM
LxMan1's Avatar
LxMan1
Tailgate up creates a pocket of air that works like a bed cover and smoothes the airflow over the bed. Leave it up.
