Transmission update
Old Jun 17, 2008 | 03:10 PM
searay280's Avatar
searay280
Transmission update
Having a new TC installed and total rebuilt. Tranny guy said the TC was shot and there was metal in the pan and that;s how he came to his conclusion that a rebuild was necessary. Quoated me $1700 for HD-Billett TC and all HD parts, says it will be much better than new stock one. Any comments on quote and diagnosis, thanks.
Old Jun 17, 2008 | 07:19 PM
Todd525's Avatar
Todd525
Was that for a complete rebuild or just the TC?? IF thats the complete rebuild, I bet you have the same tranny guy as 2 stroke.....LOL
Old Jun 17, 2008 | 09:43 PM
searay280's Avatar
searay280
New HD TC and complete rebuild
Old Jun 18, 2008 | 01:21 AM
immastrokinnow's Avatar
immastrokinnow
thats not too bad price wise. quality would have to be something you would have to find out on your own tho. i plan on using bts. higher priced but lifetime warranty is talking pretty heavy into my ear tho.
Old Jun 18, 2008 | 07:59 AM
MADVAN's Avatar
MADVAN
See if you can get a parts brakedown of what is installed.
You can spend more than 1700 in just parts alone on the trans.
Thats not getting into billet center/output shafts.
TC choice is very important.
Value of truck is falling every day.
Bill
Old Jun 18, 2008 | 08:35 AM
Todd525's Avatar
Todd525
Sounds like your getting ready to head down ripoff road if you ask me. As I posted above and as Bill said, parts are an EASY 1700. Heck, good TC will cost you almost half your quote already. Be prepared, I bet your going to have trouble.
Old Jun 18, 2008 | 12:17 PM
tjbeggs's Avatar
tjbeggs
Hold the phone here guys. Parts needed depends mostly on what the truck is used for. If this is a stock truck that rarely pulls he is probably getting a decent deal, if those are parts alone and labor is on top of the $1700.
Old Jun 18, 2008 | 12:37 PM
MADVAN's Avatar
MADVAN
1700 is turn key installed.
They have to cut corners or loose the job.
Not many looking to sink 4 to 5K into an old truck.
Your right in only building as much as needed.
Dont skimp on a choice of a TC.
Bill
Old Jun 18, 2008 | 12:45 PM
tjbeggs's Avatar
tjbeggs
Unless they are eating a ton on labor that does sound low. Ford reman (ie, same crappy parts!) is $2300 plus install.
Old Jun 18, 2008 | 01:30 PM
secondarychaos's Avatar
secondarychaos
Ya, every time i go on racer X im looking at a $2400 shopping cart. im doing a performance build (when i get to it and can afford it) but still... $1700? definately get a parts breakdown, and try to get them to let you keep the parts. make sure they arent replacing anything they dont need to, and are replacing what they tell you they're going to. also allows a second opinion afterward. just my .02
Old Jun 18, 2008 | 08:55 PM
searay280's Avatar
searay280
Thanks for all the feed back. The actual est. was appr. 1850 and not 1700 and after speaking with the mechanic, he assured me that he was installing a HD-billet TC and replacing parts with superior parts. i did ask to ut corners where he could to save a little money but the main priority was gooding a quality tranny that I would be happy with for some time. I do tow a 12k boat every weekend but only 2 miles each way other than thay it's normal daily driving.
Old Jun 18, 2008 | 10:13 PM
Todd525's Avatar
Todd525
a 280 searay that weighs 12k?? I think I might check your scale again. I worked as a Speed tech engineer at Baja Marine for brunswick corp, designed the 250, and think your off on your weight. Thats still a single right? I did mostly performance engineering, but I thought you could order the 280 in a single and a twin.
Old Jun 19, 2008 | 07:55 AM
searay280's Avatar
searay280
Twin 4.3, dry weight is 8500, I was factoring in the trailer, fuel, water, etc.etc.etc.
Old Jun 19, 2008 | 05:12 PM
Todd525's Avatar
Todd525
Ahhhh, fuel and water, thatll get ya.....wasnt thinking..........LOL
Old Jun 19, 2008 | 06:01 PM
secondarychaos
sounds to me like he might be doing a TC, shift kit and fluid change... i find it hard to believe he's doing a whole rebuild
