Sponsored by: Innova
Best place for amp?
Old Feb 8, 2002 | 11:57 AM
8996EBBroncos's Avatar
8996EBBroncos
Best place for amp?
I have an 89 Bronco. Wanted to know where everyone has installed theirs. Mine will not fit under the seat and I don't really want to put it in the console. Is there room behind glovebox? Thanx in advance!
Old Feb 8, 2002 | 12:50 PM
83bigbroncoguy's Avatar
83bigbroncoguy
Best place for amp?
From what I understand, the heater core is behind the glove box.
How about under the back seat? If not there, and you're good with
metal, try this:
http://users.superford.org/gremlin/
Click on Bronco Hints and Tips.
Then click on under floor storage box.
Old Feb 8, 2002 | 09:12 PM
Bluef4x4's Avatar
Bluef4x4
Best place for amp?
if you have a center console thats a great place to put an amp
when they broke into my bronco they took everything but the amp
Old Feb 8, 2002 | 09:50 PM
8996EBBroncos
Best place for amp?
[updated:LAST EDITED ON 08-Feb-02 AT 10:52 PM (EST)]Do you keep stuff in the console along with it? Mine stays pretty junky most of the time. I just plan on running the 4 regular speakers since I have an amplified bass tube. Also when you ran your wires did you go under the sound proofing thats under the carpet?
Old Feb 8, 2002 | 10:44 PM
Bluef4x4's Avatar
Bluef4x4
Best place for amp?
no you mount it underneath the console the only thing you have to do is extend the screws for the console
Old Feb 8, 2002 | 11:49 PM
Bluef4x4's Avatar
Bluef4x4
Best place for amp?
I removed the seats and carpet and ran everything underneath(the way it should be) I also design and install car audio
Old Feb 9, 2002 | 02:51 AM
8996EBBroncos
Best place for amp?
[updated:LAST EDITED ON 09-Feb-02 AT 03:52 AM (EST)]Ok, but did you run your wire under the insulation? And is the insulation glued down?
Old Feb 9, 2002 | 10:39 AM
Bluef4x4's Avatar
Bluef4x4
Best place for amp?
no i ran every under the carpet not insulation there is no need to go under the insulation and in my bronco it is glued down
Old Feb 9, 2002 | 12:28 PM
washington0402's Avatar
washington0402
Post Best place for amp?
co425
19
Aug 27, 2011 10:01 PM
JustinB
New Member Introductions
Jan 13, 2008 10:37 PM
DDesirableDDamsel
16
Oct 26, 2007 07:16 AM
sleepysal
Paint & Bodywork
Mar 16, 2005 10:12 AM
Tennessee Chapter
16
Nov 7, 2002 06:35 PM
