CV Boots
I have an aero, but also a 4x4 exp -
I noticed that both of my outer CV boots are swiss cheese - with multiple cracks all in a row.. both sides...
I haven't driven it since I found out about these - I can see the grease on the control arm (right next to the shocks) - so I know they have leaked out...
Don't have any clicks or pops yet, and I don't want to move it until I replace these to save the CV joints...
My question is - can I still drive it short distances as is? or should have have those done first?
Second, can I use those quick boots that are split, and allow you to do the replacement without having to pull the Joint/axle? or are those a joke compared to the real ones?
I just don't want to have to do it again in a year or something, or think they are fine, if those split boots are really not great...
anyone had any luck with those, good or bad?
Thanks
So, I did get away with it, and you might, too, but I'd probably play it safe and fix it before moving a wheel.
The more you drive it the more likely the joints will be damaged. If the joint goes, it can take out the hub too from the wobbling. Those are expensive.
They will not have a listing for the Aerostar, I left a posting a while ago about the Autozone boots that would fit if you want to search for it, think it was a Chevy truck.
You still have to pull the axle to use the split boot, but, you do not have to press the joints on and off the shaft like you would with a solid boot.
mine lasted a long time, tens of thousands of miles. I sealed mine with red rtv on the seam.
Yeah, I know I would hate the sound of the clicking, plus I'm sure a new CV Joint is pretty expensive - I'm tempted to just do the split quick boots and roll the dice, since if I'm going to pay the labor to have the axle pulled to replace boots, I might as well have them replaced too... but I have no idea what they run cost wise... on a 4x4 truck... can't be cheap...
I don't plan on driving it off road or anything, but NE winters are pretty harsh sometimes :-) -
BTW - anyone do this repair? is it as hard as it looks? :-)
do I have to pull the axle to install the splits on Explorer too?
Thanks
