Sponsored by: Real Truck
rocker panel replacement?
Old Jun 16, 2008 | 02:21 PM
shu5720's Avatar
shu5720
Hey guys. I was trying to find out if it is possible to replace the inner rocker panels on my 2000 F250 SD SC. The place where the side steps mount to is all rusted out and the steps flex way to much to be of use. I would like to replace the steps and the rocker panels if possible. If not, I just plan on torching off the steps and living with it. Cant seem to find the part listed anywhere. Thanks.
Old Jun 16, 2008 | 05:08 PM
ReAX's Avatar
ReAX
The superduties are still pretty new, rust repair parts are going to be difficult to find mass produced. If you need a spot fixed, your going to have to have it bent from scratch, if it's just the under side, I'd clean it up good with ospho or naval jelly, then paint it with POR 15 or rustoleum, and add some support for the board.
Old Jun 17, 2008 | 09:24 AM
shu5720's Avatar
shu5720
Wow. That's disappointing. At this point there's no way to work with what is left. The pass side running board has separated from the inner rocker completely in one place and looks poor at the others. Drivers side doesnt look great either. Probably better off without the boards. Thanks.
Old Jun 17, 2008 | 11:02 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Check the dealer's parts department, they have to have the sheetmetal ...
FTE/PARTS-GUY is also another source.
Worst case, find a junkyard, they'll cut out anything you want, usually
Old Jun 17, 2008 | 08:00 PM
2002 F350V10's Avatar
2002 F350V10
I think a cab swap would be the way to go if you are serious about fixing it right.
Old Jun 18, 2008 | 08:54 PM
shu5720's Avatar
shu5720
i tried FTE Parts guy but couldn't find it listed. The next step will be the local dealer and then the bone yard. I would really rather not do a cab swap as I think it would be cost prohibitive. Thanks for the help.
Old Jun 18, 2008 | 11:33 PM
ironmine's Avatar
ironmine
Stop off at a couple of local auto body shops.
Ask if they could sell you the panels, and hopefully they well tell you where they are avaliable from.
Old Jun 19, 2008 | 09:26 AM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
Old Jun 19, 2008 | 04:55 PM
shu5720's Avatar
shu5720
FTE Parts guy. Is there a diagram like that for the under side? Like the inner rockers and floor pan area? I cant tell if they are on that diagram.
Old Jun 19, 2008 | 05:07 PM
FTE/PARTS-GUY
Former Vendor
Rocker Panels Are 10129 Let Me See What Else I Can Come Up With.
Ed
Old Jun 19, 2008 | 05:11 PM
FTE/PARTS-GUY
Former Vendor
reddogracing
Jun 24, 2017 04:19 AM
BullDog58
Mar 20, 2017 08:49 AM
Rongold
Dec 14, 2015 02:20 PM
lcgeek
Oct 25, 2015 02:11 PM
swamper38s
Jul 8, 2008 10:02 AM
