Sponsored by: Real Truck
Chip for a 2002 5.4l.....
Old Jun 16, 2008 | 11:58 AM
LSAtexan4x4's Avatar
LSAtexan4x4
what do yalll have as far as chips for performance or mileage in your 5.4l trucks i want to know what company is good and makes an exeptional product
Old Jun 16, 2008 | 03:18 PM
ReAX's Avatar
ReAX
I have had a superchips blue chip, Edge new evolution, superchips microtuner and I am running a Sniper Special Forces tune now. Sniper is actual cheap considering you get to tune two gas fords for the price of the software and downloader, but it's more intricate than the canned tuners.
It's a really nice setup.
Old Jun 16, 2008 | 03:57 PM
DAFBFD58's Avatar
DAFBFD58
I'm running the edge evolution on my 5.4L. I checked with Edge directly about it because it says for the f-150 5.4L. The response from the tech guy was that it should work with maybe a problem here or there. I said problem, he said yea, it might not read a code exactly right so you might be off some where. If its doing it I am not looking at the right display because everything is right. The only thing I can think of is that when doing the custom programming it reads the stock gears at 3.50s not 3.73s. I have been too lazy to do the spin the tire thing or open the diffs and count the teeth. I really hope they are not 3.50s.
Old Jun 16, 2008 | 04:58 PM
ReAX's Avatar
ReAX
It shouldn't be 3.50, I am pretty sure 3.73 was the highest gear offered.
The calibrations are probably slightly different between the f150 and 250, but only so much that little things like that are off. However, the gears being off is going to affect the way the trans shifts, probably earlier than it should. Mine went fine, but I only used it for a couple of hours.
Old Jun 16, 2008 | 07:06 PM
DAFBFD58's Avatar
DAFBFD58
That is the thing, it shifts fine, and I have adjusted the shift points so they stay out of the high rpm range for normal driving. So I think that is the only code issue and nobody feels its an issue. I might see if my buddy can plug in and see what gears are showing on the computer.
Old Jun 17, 2008 | 05:43 PM
bbender85's Avatar
bbender85
i have the superchips microtuner on mine and like it, considering the deal i got on it. on both websites i'm on (well, looking like just this one nowadays..) guys seem to like the edge as well. custom tuners will always be your best bet, but you'll pay more for them.
i run the performance setting on mine, which you're supposed to run premium; i've been running midgrade for over a year now with no foreseeable problems. i detuned it the other day and good lord..... you dont realize the driveability you gain until you take the tune back out. i'm getting 12mpg'ish on 35's and 4.10 gears with this tune in the summer.
softailjeff
May 16, 2014 01:55 PM
bobby738998
1997 - 2003 F150
Apr 19, 2009 07:26 PM
Bernie Lomax
Computer Chips & Tuners
33
Aug 13, 2008 10:47 AM
shawn001
Mar 22, 2006 08:54 AM
98fordf250ld5.4l
Aug 14, 2004 12:55 PM
