Sponsored by: Auxito
changing the horn?
Old Jun 15, 2008 | 08:58 PM
fruth04's Avatar
fruth04
changing the horn?
anyone done this? do i have any restrictions or will anything work? im pretty open to anything from a simple horn to something one of a kind.
currently it must have been replaced at one point because it sounds like something off a festiva, i get looks from all sides when i push it, im afraid to give ppl a friendly honk lol.... any help would be good! thanks guys!
its a 03 5.4 f150
Old Jun 15, 2008 | 09:13 PM
triton_2002's Avatar
triton_2002
There are two horns, one high pitched (probably the one still working on yours) and one low pitched (not working on your truck). When both work correctly you get the "big truck" HONK! You can just replace the bad horn or get yourself one of those air train horns and give old people a heart attack....
Old Jun 16, 2008 | 09:26 PM
fruth04's Avatar
fruth04
i laid under there tonight and the old man held down the horn and they both were blowing air out how do i know which one is bad? which is the low one?
Old Jun 16, 2008 | 09:39 PM
Bikeitswift's Avatar
Bikeitswift
Use some Needle nose Pliers, and pull the spade connector off one... then the other, etc. You are going to find one dead one., and I agree, it sounds like your "low" horn is out. Any one off any 12 volt car is going to work, as long as it can bolt up.
Old Jun 17, 2008 | 06:44 AM
Ultramagdan's Avatar
Ultramagdan
My high horn went out and I replaced it no problem. The horns should have a small H or a L on the front side so you know which horn is which.
Old Jun 17, 2008 | 12:27 PM
montanafordman's Avatar
montanafordman
I had the same problem several years back - low horn went out and mine sounded pretty rediculous too. You can just buy the one that went bad rather than the whole thing - pretty easy repair.
Old Jun 17, 2008 | 09:20 PM
fruth04's Avatar
fruth04
awesome sounds like a pretty easy fix i will check it out... do i have to get a ford one one, or can i get one at autovalue or something?
Old Jun 18, 2008 | 06:51 AM
Ultramagdan
You can pick them up anywhere. A universal item it is.
Old Jun 19, 2008 | 11:38 PM
fruth04's Avatar
fruth04
gotttter fixed 15bucks later, low horn it was!
Frank33884
15
Mar 23, 2016 10:29 AM
19711969
17
Feb 10, 2015 02:56 PM
oft
13
Oct 17, 2014 08:18 PM
carchub
May 11, 2014 11:30 PM
Shadowrider123
May 6, 2014 07:55 AM
