Help with tire sizes
Old Jun 15, 2008 | 02:59 PM
robs01f250's Avatar
robs01f250
I am in need of new tires real bad and my question to you all is what is the biggest size that i can go with on stock rims with a stock ride height. 285? 295? 305?. Please help and thanks in advance for the responses.
Old Jun 15, 2008 | 03:07 PM
big poppa's Avatar
big poppa
I got 16 inch rims and went with the 285,s, but i got about a inch or so where the tire comes close to the inside fender. I don't have no spring pack yet. Looks good though.
Old Jun 15, 2008 | 03:14 PM
cangim's Avatar
cangim
I have heard of some going bigger than 285s, but I wouldn't recommend it on a stock rim. The stock rim is only 7" wide (inside flange measurement), I ran 285s on stock rim for a while without any adverse affects. The biggest thing you will notice with larger tires on a stock rim is you either run lower tire pressure or wear the center of the tire out.
