How do I dry wash my bio?
#32
Tom was talking about a centrifugal pump. Using a diaphragm pump is fine ( it's what I use). Using a centrifugal, or gear pump is problematic. When Magnesol is mixed with raw biodiesel it swells up. Using anything but a diaphragm "shears" those swollen particles, and makes it harder to remove.
#33
that is what I thought. I have a pump on order. It took 2 hours for me to filter 4 gallons and figure the pump will help a lot. thanks for confirmation.
#34
#35
#36
#37
#38
Where did you get your diaphram pump? Did you check around for a decent price? Is it manual or motorized? Thanks Tom D.
#39
#40
#41
#42
Magnesol
I don't have as much experience as most of the biodiesel guys in this forum, but I use Magnesol without mechanical pumps at all. My entire processor moves liquid off the pressure and suction of a cheap WalMart compressor and my processing tanks are steel. Once I have drained my glycerine I :
- Blow the fuel into a 94 gallon open stock tank and aereate until I know the methanol is gone. The stock tank is elevated so it is above the top of a 275 gallon tank.
- Add 2 grams/liter of Magnesol and stir with an air drill and pain stirrer for 30 minutes. Let it settle for a minimum of 2 hours and if possible overnight.
- Gravity flow into the tote through a 5 micron sock inserted into a 1 micron sock, and both are inserted into another 1 micron sock. (32" x 6" socks).
- Once in the tote I vacum it through a 2 micron Biotech canister filter into an old 120 gallon water tank. Then I blow it back through the sock filters into the tote and through the 2 micron canister filter a second time just because I can.
- From there I pressure it through a 1 micron Biotech and finally through a 1 micron absolute into the transfer tank in my truck.
- Before I run the next batch I scrape the settled Magnesol out of the stock tank.
It really doesn't take much time and I can read newsprint through 3 inches of biodiesel in a glass beaker.
Purolite and Amberlite require too much residence time to be fast enough for the average homebrewer. I think Amberlite instructions are 0.3 gallons per pound of Amberlite per hour. A soda keg holds 10 lbs of Amberlite, so that comes to a whopping 3 gallons per hour!
Sorry if I bored you all with this reply.
#43
from what I have read though, that seems a little on the low side. I have seen some people that are running with like3.5 pound per batch for a 40 gallon batch. your method only uses like 11 oz. Please unconfuse me. I have been making this stuff for like 4 years now but I am new to dry wash. Thanks
#44
#45
Follow this link to Fryerpower.com (MAGNESOL R60 and D-Sol (D60) at FRYERPOWER HOME). Read that page and then go to the Burlington Biodiesel link.
I do take pains to demeth thoroughly, I am passing the 3/27 test, and the clarity is great. At first I did not believe it would work and clear up such cloudy fuel, so I used a whopping 3 grams/liter.
Besides, the methanol has to come out sometime anyway.
