Sponsored by: Auxito
Starter or Seized Engine?
Old Jun 15, 2008 | 01:11 PM
Farakin's Avatar
Farakin
97 6cyl, 144k 4x2 stick--bought it from my sister sight unseen . She drove it from Tuscon to Mesa (about 250miles and parked it for me.
I get there today and try to start it...big chunking sound like the starter is engaging but the flywheel isnt moving. All electrical checks out.
On the off chance I checked the oil and there was none on the dipsstick.....
I try to grab the belt and push/pull it one way, won't budge at all.
Should I try and replace the starter, or at least take it off and see if I can move the flywheel?
Or should my next move be on the phone asking for my grand back? What do you guys think?
Old Jun 15, 2008 | 01:33 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Put a breaker bar on the crank pulley and see if it won't turn then.
Old Jun 15, 2008 | 02:05 PM
superdutymj's Avatar
superdutymj
You won't be able to turn any engine with a serpentine belt with your bare hands just by grabbing onto the belt. The "chunking sound" may be the solenoid kicking the armature out but the starter may be drawing too many amps to be able to turn the motor over, in other words it's bad. Take your starter off and have an auto parts store bench test it for you.
Old Jun 15, 2008 | 02:41 PM
Club Wagon's Avatar
Club Wagon
This may be premature & trying to turn it over via the crank pulley & bench testing the starter is fine advice, but, this sounds terminal.
Originally Posted by Farakin
97 6cyl, 144k Tuscon to Mesa (about 250miles I checked the oil and there was none on the dipsstick.....
I'd ask: are there signs of a large recent (still dripping) oil leak, what's the deposition of the title & how tight are you w/your sister?
These are small motors asked to do a hard job, that demand a constant supply of fresh oil. I'd "phone" to get an idea if there was Zero Maintenance & chronic low contaminated oil & see if "sister" already spent the "grand". If its a nice rust free desert pickup its probably worth sticking a salvage motor in. Perhaps "sister" can split the "grand" w/you to soften the damage?
Old Jun 15, 2008 | 03:33 PM
Farakin's Avatar
Farakin
didn't know that about the serp belt....newest car I have ever owned
If it wasn't 111 degrees right now I would take that damn starter off!
I will try the crank trick and see once it cools down out there.
Thanks
Old Jun 15, 2008 | 03:44 PM
twp's Avatar
twp
My alternator looked up an I had to have it towed to the shop, an the guy there thought it was the motor. Might be something to look at. It did whine for a mounth or so before it looked up.
Old Jun 15, 2008 | 04:29 PM
Bobby82490's Avatar
Bobby82490
This is what i would do..
Old Jun 15, 2008 | 07:27 PM
projectSHO89's Avatar
projectSHO89
I'd follow this suggestion:
1) Remove serpentine belt and see if it cranks. A compressor clutch or alternator that is locked up will stop the engine cold (Don't ask how I found that out).
2) Still no crank: Breaker bar on the crank bolt. If it won't turn, go to #3.
3) Pull the plugs and check for a hydro-locked engine
Once you get that far, you'll have a good idea of how deep of trouble the engine is in.
Steve
Old Jun 15, 2008 | 11:29 PM
Farakin's Avatar
Farakin
Love teh help guys! I appreciate the community...will do it this week and let you know what I found out
cowboy417
Bronco II
13
Aug 20, 2012 10:57 AM
chris112lee
Jan 24, 2012 10:51 PM
orthogod1
Dec 28, 2010 06:35 PM
Ingy
Jul 5, 2006 12:08 PM
fordxxx
Nov 10, 2005 06:33 PM
