Alternator wiring??
Old Jun 14, 2008 | 08:18 PM
9d4's Avatar
9d4
Alternator wiring??
I have no problem hooking up a gm alt, this is my first ford, There are 3 Wires on the harness for the alt The batt, I can figure that one out. I have an orange and black plastic cap. What are these suppose to tie into?? The alt has all kinds of posts sticking out of it. The alt was in a box of parts when I bought the truck I'm not even sure if its the right one
Old Jun 15, 2008 | 12:57 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
hook up the s terminal to the s terminal on the voltage regulator, the fld to the fld on the volt. reg. , and the big terminal to the positive side of the starter solenoid. the other posts are g or ground not used. i on the volt reg goes to switch power or ignition switch.
Old Jun 16, 2008 | 05:27 PM
spide4x4's Avatar
spide4x4
If you have an amp meter, you will have to loop the wire, which will make the amp meter inop.
Old Jun 16, 2008 | 05:49 PM
kingford72's Avatar
kingford72
the orange wire with orange cap goes right to the voltage regulator the white with black stipe and black cap goes into the main harness and is for the electric choke
Old Jun 16, 2008 | 05:53 PM
SuperSnake's Avatar
SuperSnake
There is also a article on how to do this in the Article/spec section at the top of the page in the gray bar if that will help you.
Old Jun 16, 2008 | 05:55 PM
kingford72's Avatar
kingford72
the ford alternator has a orange washer and a black washer to insulate the post from the case just hook them up to the coresponding color on the post if there no color on the alt post orange is the feild terminal and black is the stator terminal if there is no marking at all you dont have a ford alt
Benmierau
Feb 16, 2012 07:59 AM
tntlogging
Dec 30, 2011 05:57 PM
Pocca
Electrical Systems/Wiring
Jul 25, 2007 01:31 PM
xlt guy
Jun 17, 2007 07:48 PM
