valve covers
Old Jun 14, 2008 | 01:42 PM
chris491's Avatar
chris491
valve covers
Alright my truck is starting to idle very rough and has died once at idle. So I am going to check the UVC harness. On the passanger side of the truck there are two bolts on the bottom of the cover that is nearly impossible to get anything on. Any suggestions? Also any other suggestions on what might my problem be?
Old Jun 14, 2008 | 02:00 PM
chris491's Avatar
chris491
alright got the the cover off finally and that was it. clipped in nicely. So i will be checking the other side. But if that isnt it then what else might it be? thanks
Old Jun 14, 2008 | 03:11 PM
Pocket's Avatar
Pocket
If it was loose then that should be your only problem. Very common for it to happen. If it's not fixed, you should scan for codes.
