engine kit?
Old Jun 13, 2008 | 08:21 PM
lincolnrig's Avatar
lincolnrig
engine kit?
I'm about to order a engine kit, this engine is going to have a turbo. Do I need to be spesific when I order to get different piston other than the regular or all are the same and if you know a good place to order them and have a good price as well thanks
Old Jun 13, 2008 | 10:55 PM
catfish101's Avatar
catfish101
Factory turbo 7.3's had a different piston and rod. The wrist pin is bigger. The crow on the piston is different also. I think it has a steel crown.
If you are doing a 7.3 you could change the rods and update the motor.
If you are going with stock NA pistons you may want to think about milling them down some. Dave can give you more info on that stuff. I haven't gotten into building one of these for power. To many other things to. do.
Old Jun 13, 2008 | 11:29 PM
S.P.'s Avatar
S.P.
GREAT as log as Im spending someone elses money..... I would get the ceramic coated pistons, (even with my own money)
Old Jun 14, 2008 | 04:06 PM
lincolnrig's Avatar
lincolnrig
any place in particular where I can buy the kit? thanks
Old Jun 14, 2008 | 08:55 PM
George D.'s Avatar
George D.
No need to change the rods all the wrist pin dose is add rotaiting wieght. The only dfference in the turbo pistons according to the ford turbo update manuel is that they are anidised. I would go with cyramics myself maybe even get some .040 milled down pistons.
Old Jun 17, 2008 | 09:04 PM
lincolnrig's Avatar
lincolnrig
you guys recomend arp studs for the heads or the originals are ok for this engine thanks
Old Jun 17, 2008 | 11:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I haven't really looked for them, but I am not sure ARP has 7.3 head studs.
I am running the ARP studs in my 6.9 and like them.
Old Jun 18, 2008 | 09:06 PM
goodB0Y's Avatar
goodB0Y
I've seen head studs for the 7.3 I think at d.s.p. they were like...really expensive!
Old Jun 19, 2008 | 05:12 AM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
Yes, they are around $500.
Old Jun 19, 2008 | 07:52 PM
lincolnrig's Avatar
lincolnrig
but they are really nesessary ?
Old Jun 20, 2008 | 06:54 PM
Dave Sponaugle
If you intend to run high boost, yes.
Try 675 for 7.3 head studs.
Diesel Performance Specialists, Inc. - The Diesel Performance Specialists
Old Jun 21, 2008 | 10:56 AM
George D.'s Avatar
George D.
I remeber seeing a link on here some where to a thread on oil burners I think where they were talking about the DPS studs failing?
marcoelam
Jul 19, 2014 09:25 AM
jhaas63
Dec 9, 2012 07:05 PM
Hickfied
Sep 28, 2011 05:32 PM
edsherman
Sep 18, 2008 12:40 PM
DT 466Man
16
Dec 16, 2004 02:52 PM
