engine swap
Old Jun 12, 2008 | 04:35 PM
BIGCOUNTRYTRANSPORT's Avatar
BIGCOUNTRYTRANSPORT
engine swap
want to take the 360 out of my 71 f250 4 speed 4x4 and put in my 77 1 ton dually with a 351m with a c6 is this possible would like to leave the c6 in with the 360
Old Jun 12, 2008 | 05:45 PM
85e150's Avatar
85e150
351m C6 won't bolt to the 360. Diff engine series.
With all the changes--engine mounts, cooling, exhaust, accessories, the transmission--you would be money ahead to rebuild the 351M, and while you're there make it a 400 or a bit higher performing 351m.
A straight up timing set, (vs. stock retarded timing), higher compression pistons (you're buying pistons anyway with a rebuild) and dual exhaust, never mind a good intake, 500 or so cfm carb and headers, will make the 351m wake up.
The 360 is a dog stock and needs the same poke in the butt to wake up as well--the 351m fits, so I'd work it over.
jmo, ymmv
