tapping sound
Old Jun 12, 2008 | 02:51 PM
PlatinumPSD's Avatar
PlatinumPSD
tapping sound
I have a loud metal to metal tapping sound from under the front of my truck? It stops when the truck stops moving. and gets faster the faster i go. I looked under the truck and found nothing rubbing or touching. when i turn right i think it stops till the truck goes strait. I have a 2001 4x4 with 16.5 rim 35in tires and a 4 in lift tires clear fine. front axel spines free with hubs unlocked and the hubes will lock. there are manual hubes any help you could give. will have the wife move the truck back and forth to see if i can pin point the sound.
Old Jun 12, 2008 | 03:31 PM
ggirten's Avatar
ggirten
If it only makes sounds while moving then it is probably in the drive train. Check the front U joints on the axles to see if they have any movement. Check the front drive shaft the same way, but if it goes away when turning it sounds more like the axle.
Apocalypse
Feb 4, 2014 07:13 AM
operator414
Apr 28, 2008 09:08 PM
Adams1
1983 - 2012 Ranger & B-Series
Aug 12, 2004 10:57 AM
rssnape
Sep 9, 2003 09:49 PM
dfs
Apr 12, 2001 05:48 PM
