I think there's a midget tapping stuff under my hood :(
When I first crank up the truck, even if I only went into a store for 30 minutes there is a metal on metal tapping sound. It sounds like the lifters are tapping but it goes away when I drive and get the revs up. Yes I've looked for the midget and I have found some half eaten sandwiches and a few magazines specifically for "little people" but I don't see any reason they would do it so it must be the lifters right? It has a clack clack sound, and does go faster when revved so it's in the motor for sure. I run full synthetic, but have added some lucas about 3 months ago and it did nothing at all. Should I set midget traps or something else? Should I wait until tomorrow morning and get a video of it and post it up?
Will I get anything from swapping these in? http://www.ebay.com/itm/RACING-SS-MANIFOLD-HEADER-EXHAUST-97-03-FORD-F150-F-150-F250-EXPEDITION-V8-5-4L-/200996686433?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ecc560a61&vxp=mtr
It's just I would rather swap some headers on and wrap them if it will do anything since I'm already down there. I know I won't get the 100HP they claim but if it'll help any at all it would be great!
Plan on using something like this if that is the problem.
http://www.ebay.com/itm/Long-Tube-Mustang-2v-3v-4v-4-6L-SOHC-5-4L-DOHC-Mustang-F150-Header-Bolt-Kit-Zinc-/271334090572?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2cc5a74c&vxp=mtr
on
Not so fast, you need to find out what it is first. A noisy lifter, exhaust leak, an oil filter missing the drain back valve, one with a leaking drain back valve, and a spark plug about to blow out all sound about the same. Pop the hood, get a short piece of hose, and prod around until you find the source. People have just replaced a stud while on the engine also which is a bit less than doing headers. You might gain 1 or 2 HP at 5000 rpm with the headers but you wouldn't notice it.........
Maybe a time bomb, do your neighbors like you?
