Sponsored by: Real Truck
Left side front end hum
Old Jun 12, 2008 | 12:49 PM
OK RANCHER's Avatar
OK RANCHER
02' F350 DRW 4WD, lock-in hubs. Just had new tires, shocks and differential fluid changed in front end. Now when I go down the highway I sometimes get a loud humming sound coming out of the left side. It comes and goes, sometimes it lasts for a 1000' and sometimes a half mile. It doesn't do it at all at low speeds. It's not a bearing cause there is no play in the wheel when lifted off the ground, and spins fine. It sounds as if something is trying to engage. No wheel pull, just a loud humming, like running over speed bumps before tollgate. Thanks for any help.
Old Jun 12, 2008 | 01:46 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Is it a Diesel or gas?
Old Jun 12, 2008 | 02:17 PM
KelVarnson's Avatar
KelVarnson
The very first thing I would do is try dropping the truck into neutral when it is happening. My truck makes a funny sound from the front left at highway speeds, so much so that I thought it was the bearing. In fact from inside the cab, it sounded like a bearing. But when I put it into neutral, the sound went away. I suspect it might be related to my 6637 air filter in my case.
Old Jun 12, 2008 | 02:25 PM
miller_feed
That is the reason I was asking what engine he has. If it is a diesel and you have the 6637, then it could be the drone from it.
