Sponsored by: Real Truck
ABS indicator lit
Old Jun 11, 2008 | 11:28 AM
jmyotis's Avatar
jmyotis
ABS indicator lit
Last week-end the key was left on, both bateries were dead. After I charged them, I started the truck, and the ABS light comes on. What problem does this indicate? Is it in fact a problem with the ABS system?
Old Jun 11, 2008 | 01:49 PM
redford's Avatar
redford
FTE Leadership Emeritus
Does your speedometer work?
Old Jun 11, 2008 | 01:57 PM
jmyotis's Avatar
jmyotis
I tried to start it today and there was issuficent battery to crank it over. Charging now, will start it tonight and go to Checkers to run bat analyizer.
Old Jun 11, 2008 | 06:46 PM
jmyotis's Avatar
jmyotis
Ok, started it with the charger connected. Disconnected the charger and drove it a mile to Checker. As soon as I pulled out of the drvie the ABS light went out and stayed out. Battery analyzer indicated 12.6 volts and charging system at 13.1 output. Everything is fine.
Old Jun 12, 2008 | 02:39 PM
cartmanea's Avatar
cartmanea
If battery voltage is low the abs modules doesn't work correctly.
