Sponsored by: Real Truck
A/C problems, and it's Damn hot
Old Jun 11, 2008 | 07:48 PM
F250Gasser's Avatar
F250Gasser
Angry A/C problems, and it's Damn hot
I am having problems with my A/C, which is obvious from the post. I have used one of the part store meters to check my pressure level and it is a little higher than the meter says it needs to be, but when I check it the compressor cycles rapidly-every 5 seconds or so on and off- and it is only blowing mildly cold air. Any ideas about what I could check would be awesome. Also what pressure should I be running on the system. is riding with me going it feels good in here
Old Jun 11, 2008 | 08:12 PM
high ho silver's Avatar
high ho silver
There is no pre-set pressure. It also depends on the ambient temp out in front of the grill. You will have to check the low side and the high side pressure to know what is going on. Here is a generic chart to show what I mean:
Ambient temp Low side psi High side psi
85* 45-55* 225-250*
90* 45-55* 250-270*
95* 50-55* 275-300*
100* 50-55* 315-325*
Using the chart and checking with a good gage (not the el cheapo), :
1) If low side is low and high side is low- add 1 can.
2) If low side is low and high side is high-usually blockage in the system like expansion valve or orafice tube.
3) If low side is high and high side is low-usually faulty valve in compressor (gages usually go nuts when this happens)
4) If low side is high and high side is high-overcharged system also resulting in a not so cold a/c. hope this helps your diagnosis.
Old Jun 11, 2008 | 08:15 PM
PupnDuck's Avatar
PupnDuck
For a definite answer, more information is needed. What was the outside air temperature at the time and what were the high and low side pressures?
Judging by the rapid compressor cycling I'd have to guess that the system is low on charge. As a quick check, feel the low (suction side) hose just before the compressor. With the system running in max a/c and the engine at 1500 rpm or so the hose should be from slightly warm to cold. If not, the charge is probably low.
Old Jun 11, 2008 | 08:24 PM
F250Gasser's Avatar
F250Gasser
I guess I need to get some good gauges. The temp outside was about 90 when I checked it, and I believe the low side pressure was around 50-60 psi
Old Jun 11, 2008 | 11:53 PM
msbweiland's Avatar
msbweiland
Don't forget to check your compressor clutch clearances while you're at it. They are VERY sensitive and won't work right when worn out.
Old Jun 12, 2008 | 01:09 AM
aldridgec's Avatar
aldridgec
It could also be short cycling if it is overcharged and hitting the Hi pressure cutout, or something is seriously block causing the low side to suck down fast. A guage set showing both sides will tell you so much more. High Ho Silver listed some good indications as to what they will reveal.
