Fan Clutch???
Old Jun 11, 2008 | 09:31 AM
300ForMe's Avatar
300ForMe
Fan Clutch???
Hi Everyone,
Have a truck here in the garage that is running a little hot. It's a '78 F-150 Ranger. Been poking around to try to find the problem. I noticed that the fan has a clutch on it. I've never seen one of these old Fords with a fan clutch. I didn't think they started using fan clutches until the mid-80's. So, I'm beginning to wonder if that's the problem. The truck is a Lariat and does have factory air. I'll admit, I've never worked on one of these old Fords that had air conditioning in it. So, does anyone know if the fan clutch is orginal equipment for the truck, or did the someone, somewhere, graft one on from a later model truck? The motor is a 400, by the way.
Thanks!!
Old Jun 11, 2008 | 02:36 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Some of these trucks did come with fan clutches.
They were mostly offered with Super Cooling, or Air Conditioning equipped vehicles.
Old Jun 11, 2008 | 03:08 PM
GLR's Avatar
GLR
I've got one on my 78 F150 400 eng with air. Had overheating problems with my 86 replaced fan clutch and problem solved.
Old Jun 11, 2008 | 03:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Fan clutch 351M/400 1977/79
The first use of a fan clutch (known originally as a viscous drive) was in 1963 on FE engined passenger cars with A/C.
This same fan clutch (later updated to a '64 p/n) was used on 1968/72 F100/350's with A/C: C4SZ-8A616-B.
1977/79 F100/350 & 1978/79 Bronco ~ 351M/400 with A/C or Trailer Tow package:
E1TZ8A616B .. (replaced E1TZ-8A616-A & D4TZ-8A616-A)
MSRP: $234.48 / ftepartsguy.com price: $135.06
Old Jun 11, 2008 | 09:54 PM
4x4 Bart's Avatar
4x4 Bart
Was a fan clutch ever used on a 300 six?
Old Jun 11, 2008 | 10:04 PM
Dr. Dirt's Avatar
Dr. Dirt
I don't think there is a fan clutch on my 300, but my fan is direct drive.
Old Jun 12, 2008 | 12:14 AM
partsman01's Avatar
partsman01
My 1977 with a 400CI 6.6litre has a fan clutch
Old Jun 12, 2008 | 05:42 AM
NumberDummy
No 300 fan clutches are listed in the Ford truck parts catalogs till 1982.
Old Jun 12, 2008 | 08:07 AM
300ForMe's Avatar
300ForMe
Thanks for all the help!!!!!
Old Jun 12, 2008 | 10:08 AM
beartracks's Avatar
beartracks
I highly recommend an RV type heavy duty fan clutch. They are both centrifigal and thermally operated. If you need lots of cooling they are the bomb.
Old Jun 12, 2008 | 02:53 PM
81-F-150-Explorer
Fan Clutch conversions are very easy though.
If you want to do the conversion, Dr. Dirt, all you have to do is give your local auto parts store the year make and model of your truck, engine size, and ask them for a thermal fan clutch, and fan clutch Fan blade, and they will set you up with what you need.
The Fan clutch takes place of the fan spacer and bolts directly to the water pump. You will need the "fan clutch fan blade", because of the difference of the blades.
hope this helps.
