steering
Two pitman arms were offered from the factory, one was 4 inches long, and one was 6 inches long, so naturally the longer one is better.
Next would be to obtain a block that bolts under the steering arm. Since the hydro ram does the majority of the turning, the longer studs, and added leverage by using a cheesey block is minimized.
I have set trucks on 8 inch springs and still had a decent radius, and kept angle to a minimum.
Now, this will still cost time and money, and the real answer is a true crossover. Seems to me that spending time and money on an antique push / pull system is sort of a waste.
If you are going to raise that truck, you may just consider upgrading the steering now. You can perform the upgrade for reasonably cheap.
You original post would have implied an early power assist system.
Now that being said, regardless of which system you have, you have to look at one thing, and this is the arch that the axle moves at (during suspension cycles) is different than the arch that the drag link will allow. The short drag link will always prevent proper steering, and wil always bind way before the suspension will max out. Limiting straps and bumpstops only prevent max articulation, and adding them to limit steering bind is counter productive.
That truck can have pretty good potential for flex, but is really limited by the steering geometry.
The next thing to consider is the limited turning radius when the the suspension is compressed. It is entirely possible to have the steering whell turned all the way, and have the wheels pointing perfrctly straight. Not good when trying to navigate a tight trail in a fullsize rig.
Since you have had spherical rod end failures already, there are a couple of things to consider. Failsafe devices for rod ends such as a spacer and large washer to prevent the end from popping off of the ball, or even considering a larger rod end. Quality is key here, and failures can be kept to a minimum.
Large trucks can utilize a chebby 1 ton tie rod end ES2026, and ES2027 with a custom made drag link if spherical ends are not desireable. Now TRE's take up more space, so keep an eye on how much room you have, but again the answer here is crossover, or even some form of inverted "t" at a minimum. Inverted "t" will be a little more difficult because of the pass side leaf spring, but can easilly be converted.
If you have a later 77.5 to 79 truck, you can use the same stock steering box, but if you really have a truck with power assist, then the box will have to be removed.
Here is a couple of poser pics of my junk, Image of Poser flex pics - Photobucket - Video and Image Hosting and you will notice that even with one front tire over 40 inches in the air, I have zero steering problems, and not a thought of binding. Still have to work out some issues with my springs, but the steering is right on the money, and this thing drives real well even at highway speeds.
Turning radius is vastly improved also.
67-77 @ NTW
This will allow you to perform the upgrade component at a time, and still maintain a budget. These boxes are cheap, and easy to re-build, and even easier to upgrade later down the road if hydro assist is needed along with your power steering upgrade.
Image of saginaw power steering conversion - Photobucket - Video and Image Hosting
So close to having a complete crossover.
FordWorth, you are a very smart man. I have been searching and searching for a conversion to do on my 76 HighBoy. And yours tops my list. It is the simplest and logical to go with. All the other I have seen went with a pitman arm threw the frame/lift spring opening. Which is fine, but the first time I stuff the tire the arm is shot.
If you have anymore Ideas on this system that you have not posted or ideas to make it better please let me know.
And thank you man.
