1978 - 1996 Big Bronco
'85 engine rebuild
Old Jun 10, 2008 | 08:24 PM
Mark-I6's Avatar
Mark-I6
'85 engine rebuild
I am in the process of tearing down my I-6 engine in order to replace the block and was wondering if I have to drain the tranny to pull the block out. Its an auto if that makes a difference.
Thanks in advance for any replies.
Old Jun 10, 2008 | 08:52 PM
greystreak92's Avatar
greystreak92
You WILL want to disconnect and plug the cooler lines that run from the transmission to the radiator. Remove them completely unless you are sure you can get the engine out without damaging them. Then plug the radiator and the transmission ports.
Otherwise, there should be no need to drain the transmission. Take care to keep the torque converter seated on the transmission input shaft when you pull the engine. Otherwise you will have to deal with the torque converter draining itself all over the place.
Old Jun 10, 2008 | 10:15 PM
Mark-I6's Avatar
Mark-I6
Thank you very much for the info, I feel I have gotten in a bit over my head on this little project
Old Jun 11, 2008 | 10:46 AM
Kemicalburns's Avatar
Kemicalburns
you going to do any upgrades? make sure you dont get a block with an overbore of 60 otherwise the motor will run hot. running a bit higher compression with this motor really wakes it up as well. are you having a shop do the rebuild or are you buying a motor from who?
Old Jun 11, 2008 | 01:18 PM
Mark-I6's Avatar
Mark-I6
I already have a stock rebuilt motor from a shop called Jones automotive. The only upgrades I am making are going from a single barrel carb and intake to a 4 barrel. I also got rid of most of the old emissions crap that was on there and exhaust changes.
Its a full rebuild though. New heads new exhaust, including headers.
Old Jun 11, 2008 | 01:30 PM
Kemicalburns
right on, i love the 300-6. its a great proven motor. wish my fsb had that motor
Old Jun 11, 2008 | 03:30 PM
greystreak92
Mine will in a couple months... gotta finish the new garage first though. Mark-16, are planning on going with Clifford components on the intake and exhaust?
Old Jun 12, 2008 | 03:02 PM
Mark-I6's Avatar
Mark-I6
I went with an offenhauser intake manifold and the exhaust manifold/headers are a cheapo that I cant recall the name of the brand, got em off Ebay, and an edelbrock carb.
riverbottom
1997 - 2003 F150
Nov 24, 2009 06:29 PM
fiftyfordfloored
Sep 4, 2008 11:02 PM
ejriede
Modular V8 (4.6L, 5.4L)
Mar 14, 2006 02:25 PM
Wellcraft
Jan 18, 2005 10:46 PM
