frame mount?
Old Jun 10, 2008 | 12:10 PM
OldBlue68's Avatar
OldBlue68
frame mount?
Is a frame mount the mount that bolts to the crossmember and to the motor mount? Or is it called something differnt. sorry for yet another dumb question
Old Jun 26, 2008 | 04:19 PM
mudslingin'78's Avatar
mudslingin'78
I dont guess I understand what you are asking.
Old Jun 28, 2008 | 07:25 AM
Byteme's Avatar
Byteme
Yes, that is indeed a frame mount. May also be referred to as an engine perch.
Not to be too cliche, but the only dumb question is the one you don't ask. This is what this community is here for.
Old Jun 28, 2008 | 08:41 AM
Greywolf's Avatar
Greywolf
Also sometimes called a saddle.
Each of them are for specific engine series, but the easy way to find out what fits what is to look inside the mount from underneath. The engine size(s) it is made for are stamped into the steel. 255 to 351W is one frame mount set, big blocks and I-6 may be the same mounts, not sure. V-6 mounts are their own thing.
Rivets need not hold replacement saddles on - but I recommend grade 8 or higher bolts.
