99 ford F150
Old Jun 10, 2008 | 10:49 AM
BCCC's Avatar
BCCC
99 ford F150
I have a 99 ford F150 with the 4.7 triton, I am wnting to put the 5.4 in it though, is it a straight swap?? Also where can I find the 5.4 crate motor??
Old Jun 12, 2008 | 06:54 AM
projectSHO89's Avatar
projectSHO89
You would also have to change the engine harness and the computer, also, at a minimum.
Steve
Old Jun 12, 2008 | 09:41 AM
BCCC's Avatar
BCCC
how much is that??
Old Jun 12, 2008 | 11:09 PM
LxMan1's Avatar
LxMan1
You actually have a 4.6L and you will need to get that stuff from a donor truck at a local salvage yard.
Old Jun 12, 2008 | 11:19 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
you actually only need the motor, i used the 4.6l manifolds, and intake downtube so the EGR would work. im still running the coil pack ignition with a 4.6l comptuer tune. works decent enough...just not maximum... i think i ran a 16.4 1/4 mile with it here recently... i think with my current custom tuning ive done and swaped my Micky Thompsons for some AT/s for the summer i could actually break into the 15's in the 1/4 mile
you do have to widen your y pipe, and make some custom brackets for your coil packs if you decide to use your computer, ecm, and wire harnes... its really easy, and i could post some picks if you wanted. its not a bad swap at all, well worth it. aside of needing a good tuner to get optimal performace.
Here in the midwest theres not as many tuners...
Old Jun 13, 2008 | 06:50 AM
projectSHO89
No, his 4.6 is a coil pack ignition system, the 5.4 is a COP system. That means the harness and computer need to come along for the swap.
Steve
Old Jun 13, 2008 | 12:05 PM
BURNSTOUGHFORD
lol, i did the swap, i now have a 5.4l and it works fine. just needs a retune... if he has the harness and ecm great, but its still going to need to go to ford to have the PATS redone....
SOOOOO....what im saying is that if he wants to swap the engine make more power and not have to have the computer retuned, just swap the motor and reuse the 4.6l ignition system.
Old Jun 13, 2008 | 06:15 PM
galaxie641's Avatar
galaxie641
Yep you can use the "older" ignition that is stock. Beat me to the exhaust width. Jasper as well as many other engine builders have engines for sale with warranties, as does Ford.
Do you have a stick or manual tranny?
You also want a '99+ 5.4L they will have around 30 more HP due to the improved heads/intake but there may be a few sensors in the newer engine that will not have anywhere to plug into or just need to be plugged up.
Old Jun 13, 2008 | 09:55 PM
BURNSTOUGHFORD
the only sensor or what ever that doesnt have a home with the 5.4l is the variable volume intake underneath aluminum intake.....
907outdoorsman
1997 - 2003 F150
Mar 4, 2013 08:49 AM
brokenpaw
13
Feb 18, 2008 11:02 PM
micahman
Modular V8 (4.6L, 5.4L)
Feb 4, 2007 03:40 PM
marshall99f150
Aug 15, 2006 05:45 PM
One Bad 88 GT
Jan 26, 2004 12:04 AM
