Sponsored by: Real Truck
Removing headrest?
Old Jun 10, 2008 | 02:56 AM
thedaddycat's Avatar
thedaddycat
Removing headrest?
I bought some Wet Okole seat covers and need to remove the headrests in order to get them on. I've been told that they will come right out the top of the seat, but mine only go up so far and then it's like they hit a brick wall. I've tried it with the adjuster depressed and with it not depressed, still seems like it's hitting on some kind of a stop. Any help would be appreciated, thanks for any suggestions offered.
Old Jun 11, 2008 | 03:48 PM
Beerstalker's Avatar
Beerstalker
There are 2 tabs you have to depress in order to get it all the way out. If you are looking toward the back of the truck you can easily see the adjuster for the right post as it sticks out from the rest of the plastic on the left side.
The left post has an adjuster on the left side that is flush with the main plastic peice. You have to push it into the plastic, while you also push in on the right post adjuster, then the headrest will pull up and out.
Old Jun 11, 2008 | 09:56 PM
thedaddycat
Thank you very much! I was beating my head against the wall.... err headrest on this one. I knew there had to be something simple I was missing, never even thought about there being two tabw to press. Rep points coming your way!
DIXIEDOG1
2009 - 2014 F150
Feb 11, 2012 09:41 AM
rob6095
1997 - 2003 F150
May 26, 2011 07:59 PM
echoy97
Escape & Escape Hybrid
Feb 21, 2007 09:31 AM
camperspecial
Sep 3, 2003 10:10 AM
